Question about Polaroid MACRO 5 SLR Instant Camera
Hello. I recently got a Polaroid Macro 5 camera. Sometimes when I press the shutter button lightly it makes a beeping sound and I have no idea what that means. (If I press it fully it will take the photo and I've had no problems with the camera.) I'd just like to know what the sound means! Thank you so much for any help you might offer.
SOURCE: Polaroid miniportrait 403
push the button all the way down- a half push is just to test the range
Posted on Jul 08, 2007
  • 124 Answers
SOURCE: Stopped taking pictures
How old is the film in camera & when did you put in the film?
Polaroid's battery is built in with the film package.
If the package is old or been in the camera for a long time battery may be low or dead.
Try changing film out.
Good Luck! Hope this helped. Please rate.
MSG back if you need more help.
Posted on Mar 11, 2009
SOURCE: i purchased a polaroid camera from a 2nd hand
hi~ i'm looking for a Q-light for Polaroid one step Plus but couldn't find one in Taiwan.
do you guys know where could i get one?
Posted on Feb 15, 2010
Obertelli
  • 3006 Answers
SOURCE: can you still get film for the polaroid macro 5
In short, no. It's a long obsolete and specialised camera. Polaroid Spectra film will also work in your camera, but is also no longer made and is as common as fresh **** ****: if you find any it's likely to be useless now. Your camera is now a historical oddity and is of interest to collectors only, but as it can never be used the value isn't high.
Posted on Aug 07, 2010
Obertelli
  • 3006 Answers
SOURCE: I have an old Polaroid Land Camera model 95A. I
It's been a long while since I played with a 95A, so rather than making guesses you may wish to click here for a free user manual. The red switch was to release the film to allow the photo to be pulled out after being taken.
I hope that my reply has been of assistance to you and that you're able to briefly spare the time to rate my answer.
Posted on Sep 14, 2010
Sometimes shutter release button is very slow, other times it is fine. Just began happening. Do you have any idea what the problem may be
On page 28 of the advanced features manual from your camera, it explains how AF works. Focusing should happen while you press the shutter realise button half way down. Depending of the light, contrast and subject this can take from half a second to sometimes twice or three times as long. When in focus, you hear a beep and see a green light on the display. Then you can make the composition (or fine tune the outline of your picture) and then you press the button fully. The compact camera does work different from a DSLR. If you are user to a DSLR, you have to learn the compact, because it needs more time to focus, because the focus system is completely different.
Mar 22, 2014 | Panasonic Lumix DMC ZS19K 141 Megapixel...
I have a Nikon Coolpix s70 and the clarity of my pictures are horrible. I get on average maybe one good picture out of 5 taken. They are all very blurry. How do I reset my settings and which...
Check the LCD display. Is there a symbol of a flower in a pot? If so you have accidentally left the camera set to "macro" (close focus) mode. if this is not the case then add a comment and I'll provide the next most likely cause.
Usually the macro setting is activated by pressing on one of the thumb-pads around the select button, it will also be marked with a flower symbol. If I'm wrong about how to deactivate macro, then add a comment and I'll research a more accurate answer for you.
Jun 26, 2011 | Nikon COOLPIX S70 Digital Camera
My pictures are not clear. They appear blur
With digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
Finally, make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on objects at normal distances. The icon for Macro mode is a little flower.
If none of these is the problem, there may be a fault requiring service (probably not economically viable unless they will do it under warranty).
Nov 27, 2010 | Polaroid Cameras
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
Apr 03, 2010 | Polaroid A500 Digital Camera
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Wont speed up even with new batterys
The shutter button features a two-stage action. shutter_button.gif Pressing Halfway Pressing halfway automatically sets the exposure, focus and white balance.
The indicators light or blink as follows.
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
Sep 24, 2006 | Canon PowerShot A400 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Rely on the LCD Monitor, especially for Telephoto and Macro photography. Due to differences in depth perception, the Viewfinder is not as accurate at the LCD Monitor. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Better Focus
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Polaroid MACRO 5 SLR Instant Camera Logo
42 people viewed this question
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
homefixit
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
