Question about Whirlpool Washing Machines
When i close the lid, it will not start. Only when I push down on the lid several times, will it start. Getting harder and harder to start.
  • Whirlpool Master
  • 43,501 Answers
Lid switch is broken...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 29, 2010
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Dash light looks like a car with trunk open is lit up. All doors and trunk are secure. What is the cause?
The trunk lid is not closed tightly enough....or the trunk lid switch is not properly adjusted.
Try closing the trunk lid a little harder once to see if it works,,,or have someone push down hard there while you watch the panel light.
Hopes this helps
Jun 27, 2011 | 1999 Ford Escort
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
Hi i have just got a new Pavilion DV7 only a few weeks old on boot/start up it starts then goes off several times before it starts to load windows the fan starts and the lights come on then goes off...
Run CHKDSK/F to check for errors. There may be an error on the hard drive.
Closing the lid when closing down, puts it in sleep mode and it will restart much easier but the error should be removed.
Jan 20, 2011 | HP Computers & Internet
Machine (mhdsr165foww) washes and drains but when it gets to the spin cycle it does not start sounds like the lid is not locking. Lights flashing on controll pannel: Lid, rinse, spin. Any ideas?
Sounds like the lid switch is malfunctioning. The contacts in the switch may be dirty or rusted. Push down on your switch button and listen for the little click, if it still has a little click to it, spray a little WD40 on it while repeatidly pushing it down several times. Reply back to this post and let me know how you made out.
Dec 02, 2010 | Washing Machines
My Whirlpool ultimate II will fill up and then stop
The lid switch need to be replaced. You might try to lengthen the rod that pushes it down. You might try trimming lid bumpers with a razor blade to make the rod go down further.
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Help
make sure the lid is making contact with the switch when the lid is closed, listen closly for a "click" noise upon closing the lid, if you dont hear anythig the lid is no tbeing recognized as closed therefore will not enter a spin mode for safety reasons.somtetimes by pressing down harder on left side of the lid you can get it to startup. if this is the case a simple solution may be in order, after lifting the lid make sure the scrrws attaching the lid to the hinges are tight, then if you place your hand under the left rear side of the lid you feel the lid actuator( its the opposing side to the door hinge) with a nutdiver( or similliar hollow pointed metal object) slide it over the metal hinge and apply force to slighty bend to toward the reare of the machine( as you apply pressure the lid will want to push against you , thast s normal its the hinge your bending) after slighty bending now see if tyou can here the click?
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Jun 17, 2008 | Washing Machines
Cartridges jammed
Try pressing the "copy" button and then the black "start" button. I did this a couple of times and the printer started working again.
Other people have had success when they open the lid, pull down the gate (to expose the cartridges) and then push in the little button on the left (to fool the printer into thinking the lid is closed). With that button pushed in, try pressing the "copy" button and then the black "start" button. The printer will make some working noises. When you close everything up again, it should work.
May 17, 2008 | Canon Office Equipment & Supplies
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
