How to I open the laptop, remove the old keyboard and replace it with a new one
    Scholar:
  • 183 Answers
Not enough information to give you a complete guide, but most laptops require a top cover (in front of the hinges) to be prised off to reveal several screws which are holding the keyboard down (Dell, Toshiba, some HPs and cheaper Sony).
Other laptops (acer, asus, medion etc) have screws accessed on the rear of the laptop to release the top cover and keyboard.
Once you have access, note carefully how the keyboard ribbon cable is attached to the motherboard, as reconnecting can occasionally be awkward.
Posted on Aug 29, 2010
How to replace the fan
Generally that requires opening the case and removing the old one. Most can be done by removing the keyboard on laptops and then removing a few screws on the old fan and replacing with a new one.
Jul 21, 2014 | Sony VAIO VPCZ116GX PC Notebook
Tip
How to Install Compaq Laptop Keyboard
Compaq laptop keyboards have a variety of sizes and configurations to fit the design of the laptop itself like smaller laptops or larger laptops with full-size keys. You might now find that the keyboard or keypad exhibits problems such as sticking keys or general unresponsiveness from your owning Compaq Presario laptop because of several years'using. Besides, you have made sure that your old keyboad is clean but it still doesn't work well. Then you have to install a new one. So how to do it? Don't worry, you can DIY your Compaq new keyboard via this guide.
Step1. Exit Windows and turn off your computer.
Step2. Unplug the power cord and modem and network cables.
Step3. Place your laptop on a clean and disconnect the old keyboard. Open your laptop screen as far as you can.
If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
Step4. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Compaq Keyboard in place.
Note: Keep these screws in a safe place.
Step5. Gently tug the Compaq Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Step6. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right.
Step7. Connect the power on your laptop and verify that the new Compaq Keyboard is working.
OK, well done! Compaq keyboards are inexpensive, easy to find and quick to install. Actually, all Compaq Presario laptops have reasonable prices and you don’t have to worry if something breaks down as replacements are easy to find and cheap to buy from Papatek. Papatek Compaq Laptop Keyboard are specifically designed for each Compaq laptop brand and model.
on Aug 31, 2010 | Computers & Internet
Replace satellite keyboard
These days, laptop computers, like the Toshiba A305, are designed so that many of the components can be removed and replaced.
This includes the keyboard, which can be removed even if it becomes broken or damaged. This is good because it means you don't need to toss out the whole computer, but you may be worried about how to do it if you don't know much about computers.
The good news is that the process is fairly straightforward.
Turn off your Toshiba laptop and remove the power cable if it is attached.
Close the screen and turn your computer upside down.
Slide the rectangular battery out of its compartment on the underside of the computer.
Turn the keyboard right-side up and open the screen so you have full access to the keyboard. Locate the rectangular plastic frame just above the keyboard.
Insert the top of your screwdriver in the seam at the end of the frame where it meets the side of the computer, and gently pry the frame up.
Remove it from the computer.
Remove the two screws above the keyboard and set them aside.
Lift the keyboard up and unplug the thick ribbon cable where it connects at the back of the keyboard. Set the old keyboard aside.
Plug the cable into the port in the back of the new keyboard and fit the keyboard over the computer.
Replace the screws and bezel, and you're finished.
Hope this helps
Nov 04, 2012 | Toshiba Satellite A305D-S6848 Notebook
Need instructions to remove and replace the keyboard
No, not really, it will most likely just come as a keyboard.
its not that difficult to replace a keyboard,
here are pictures of the process.
http://www.irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
let me know if you have any other questions, yes its another model but its very similiar, I have a compaq laptop here and a acer laptop, on both laptop I would replace the keyboard pretty much the same way - I've had the keyboards off from both of these, and its very similiar on both brands I don't have a toshiba here but looking at those steps / picture its pretty much the same process.
May 21, 2009 | Toshiba Satellite A135-S2386 Notebook...
How to replace an Advent 7000 keyboard?
disassemble your keybr from laptop n using a tweezers to remove old pin n reassemble new pin. using it tool press new pin until "klik" sound.
Apr 05, 2009 | Computers & Internet
How to remove key board from bakard bell easy note sw51-201
Mary,
At the bottom beside the lock sign take out the screw. Open laptop and move the top part panel to the right this will open the keyboard acces..
Jan 14, 2009 | Computers & Internet
Fitting new keyboard
Link for dv2000
Page 127 of the PDF starts the keyboard disassembly.
Apr 06, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
David Payne
David Payne
