Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
It turn on , revolve but no air comes out - Lasko 48" Xtra Air Tower Fan with Air Ionizer
I am having the same problem. Did you ever fix your fan?
Posted on Sep 20, 2010
my lasko tower fan gets power and the light turns on and it will rotate but it wont blow air out and i tried cleaning it and still wont work?
Posted on May 19, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Check motor bearings and thermal fuse on motor winding
Posted on Jun 14, 2014
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
My mac book air is not shutting down from 12 hours. i can just see desktop background and a coloured disk revolving.can u plz help me.
It sounds like it locked up. Hold the Power Button down for 15 seconds. The machine will power off and allow you to turn it back on.This is not recommended to do all the time - but in your situation it's your best bet.
Feb 28, 2011 | Apple MacBook Air
I have a danby portable air conditioner with no manual. The picture shows two ducts going outside. My question is why does the intake go outside?
On a portable a/c unit the cooling is done by taking heat out of the air inside and dispensing it outside.
That's accomplished by washing air over the heat coil in the unit, then the air goes back outside to let the heat out there.
You'll need inlet air, and outlet air to accomplish that.
Inlet air is cooler as it comes in, then that air absorbs some of the heat inside the space you're cooling and turns around to go back out leaching heat outside.
Most likely scenario.
There may be another need for outside air revolving around positive pressure inside the conditioned space.
Let me know if that doesn't solve your situ.
Russini
Oct 30, 2010 | Danby Heating & Cooling
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Feb 24, 2010 | Microwave Ovens
Light comes on, trun table revolves, does not heat
the magnetron might be defective, also check the door interlock switches, they cause a variety of problems.
Jun 28, 2009 | LG LRM1250 Microwave Oven
Clicking sound as it revolves
If the fan is a ceiling hugger the wire connectors could be possiblly rubbing the motor
May 03, 2009 | Heating & Cooling
Call for service CEA0
This means the revolver (holds the 3 color toners/developer units) never returned/moved to its "home" position.
It could mean a bad or dirty home position sensor or a faulty/bad logic board or possibly a bad motor (not rotating the revolver correctly) try cleaning or replacing this sensor first.
if you remove the covers from the left side of the copier you will see the revolver unit. the sensor is located at the rear of the revolver unit mounted on the frame of the copier.(easy to see) there is one screw holding it and a small wire connector.
These copiers are "famous" for having dirty sensor issues.
If the revolver/machine makes an odd noise when starting up, caused by the revolver then its starting to turn (run the copier with the side cover open so you can watch it) then it would point more to being a drive problem.
Mar 26, 2009 | Toshiba E-Studio 3511 Color Copier
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
2,458 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
