Question about Kenmore HE2 Plus Front Load Washer
Hi, I have a Kenmore Elite HE3 Front Loader. It will go thru wash cycle, but then at the end, it will have a "2 F" blinking and will not rinse and drain. Please help!
  • 5,911 Answers
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span><span>"F02" is a Long Drain error code. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir just needs to be cleaned out. The following link explains how:<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade" target="_blank">http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade</a><br /><br />If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.<br /><br />I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well. <br /><br />It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. Since you found screws in the pump, you may have damaged the small impeller and/or the motor. If this is the case, you will have to replace the pump in order to get the error to clear. The following link explains how:<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load" target="_blank">http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load</a><br /><br />Replacements parts (if required) can be purchased at any of the following websites:<br /><br />searspartsdirect.com<br />pcappliancerepair.com<br />appliancepartspros.com<br />repairclinic.com<br /><br />Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. <br /><br /><br />NOTE: <span>For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside. </span><br /><br /><span>To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls. </span><br /><br /><span>The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.</span><br /><br /><span>Read through the information provided and let me know if you have any further questions.</span> I hope you find this information helpful.</span><br /><br /><span>NOTE: "SUD" is a suds error detect that can commonly occur in conjunction with the "F02" error. This is a result of too much air being detected in the drainage system. In most cases, correcting the drainage problem will corect BOTH error codes.</span></span></span></span>
Posted on Aug 29, 2010
  • 7 more comments
  • Jeff Rockwell
    Jeff Rockwell Aug 29, 2010
    I apologize for the formatting errors. I'll repost here so you may be able to read it
    http://www.fixya.com/support/r3574284-ch...
    If the link does not work, cut and paste to your web browser.
    I recommend you remove the inlet hose, as well, and inspect for clogs. It is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
    repairclinic.com
    NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
  • sounantha1 Aug 29, 2010
    Thank-you so much for your advice and how to fix the problem. My husband is working on it now! Hopefully it is just something plugging the drain!
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
