Question about Whirlpool AD50USS Dehumidifier
I have a Whirlpool dehumidifier, model number AD50USS0. The unit runs but does not dehumidify. There is no water in the reservoir and the part that makes the most noise is silent. The fan operates just fine. I would like to know if this is a reasonable repair or do I need to replace the unit. Thanks for your help. Jim.
  • Whirlpool Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 29, 2010
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
I have Whirlpool AD50USS0 Dehumidifier, but does not collect water
heatman101
Dec 15, 2010 | Whirlpool AD25BBK Dehumidifier
Unit runs but is not operating properly.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 05, 2010 | Whirlpool AD75U Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
The unit turns on and sounds like it is running,
Your coil temperature has to be below the dewpoint of the air in the basement to remove the moisture. If you can set the temperature lower or the fan speed lower it will help.
Aug 08, 2009 | Whirlpool AD40DSL Dehumidifier
Water not collecting in reservoir; seems to be building up in the top and running out left side (as you're facing unit)
Before I can fully troubleshoot this, what is the exact model of your Kenmore Dehumidifier. Please use the comment button to post up the exact model number.
Thanks
Jun 30, 2009 | Kenmore Dehumidifiers
I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Jun 08, 2009 | Whirlpool Dehumidifiers
Dehumidifier does not fill up with water anymore
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Oct 22, 2008 | Whirlpool Dehumidifiers
Whirlpool AD50USS Dehumidifier Logo
460 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
