Installing memory We have been attempting to install memory after taking it out to check what type to order for the other memory slot. Haven't been able to get the computer to work right since then.
    Brigadier General:
  • 6,966 Answers
Try removing the memory again and clean/rub the little gold pins with a pencil eraser. When inserting back, you may need to wiggle it a bit to ensure that it is seated correctly and makes a snug fit to the slot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
How do I install an additional RAM card
The IBM NetVista A22p has 3 memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
*2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
*3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
*4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
*8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
*12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
How do I install memory on my IBM NetVista A22p 2292-xxx?
Memory installation help guides can be found at the following link.
Memory Installation Guide
Installing DDR DDR2 DIMMs
Installing SDRAM DIMMs
Jan 11, 2011 | IBM NetVista A22p PC Desktop
HOW TO ENABLE 289 DIMM D01 is disabled in server 2008.
terrible question; please add more detail
if your system has a dual CPU socket, perhaps you don't have a second cpu (where more memory banks usually require that second cpu socket to be populated in order to use the dimm slots); doubtful, but there could also be a jumper on your mobo
or maybe look in your BIOS; that's where things are enabled/disabled (i.e. server 2008, afik, doesn't have a way to specifically disable a dimm slot)
the mobo (or system) manual may have guidance for memory installation; e.g. sometimes there's a size or slot population type table (or compatibility; i.e. maybe the memory you are installing is dual rank and the system only takes single, thus it appears that the slot is disabled)
Jan 11, 2011 | IBM eServer xSeries 3200 (43635FU)
# of RAM slots
There are two models for this type of desktop, the first having only two DIMM slots, but that takes PC2700 Ram, you have stated that yours takes PC3200 which would make it the second model in which case your model has (4) DIMM slots, each slot is capable of holding a 1 GB stick of ram for a total of 4 GB. Your RAM specification is DDR PC-3200
Jan 12, 2010 | Computers & Internet
It seems i have lost the photos that were in tht camera. a little confused about internal memory and what that means
Some digital cameras can take pictures with out any memory card installed, some have no way to use a memory card. Most digital cameras use some kind of memory card which can be inserted in the camera's card slot. When the card is not installed, some cameras can take internally stored files, either video or picture files. In order to get those files on a card, a card must be inserted in the memory card slot then go to the menu to copy the files to the memory card.
Nov 08, 2009 | Kodak EasyShare C633 Digital Camera
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Tried to upgrade RAM now computer won't boot up
check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
Jan 10, 2009 | Computers & Internet
I have just installed more memory to my computer and do not notice any difference in the speed of my computer
you may have installed memory that may not be compatible with your motherboard
do you know what type of mother board you have..
your memory must match in this categories
1. type (ddr, ddr2, sdram, simm, rimm)
2. speed (measured in mhz or sometimes given as a pcXXXX number)
3. cas number.
4. whether is ECC, parity, buffered, registered, non ecc
5. check your motherboard documentation to find exactly in what slot your new memory stick should go and which one should go first and which one should go second (ex. if you have dimm slots and you have 4 slots (2 pairs of different color) you may need to install one memory sticks like this: memory - empty - memory -empty
if one of the items that should be matched does not correspond your computer could work but it will work at the slower speed (ex. memory 1 (slow) + memory 2 (faster) = speed of memory 1
note: don't confuse memory capacity (1g, 512mb) with speed (333mhz, pc2700)... the best thing to do is to check the documentation of *********** board or even take the memory stick that you originally have and have the store looking for the memory that you need...
Sep 22, 2008 | Computers & Internet
Install new memory
Take the case off your computer. There are either 2 or 4 slots for memory. Depending on if all of your slots are full, you might need to remove your old memory in order to install the new memory. If all your slots are full, remove all the old memory. There are little switches on both sides of each memory stick. You will need to push the switches over in order to put the memory in the slots. Once you completed the installation, turn on your computer. Windows will automatically reconize the new memory.
Jun 18, 2008 | Compaq Computers & Internet
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
