Question about HP Officejet 5610 All-In-One InkJet Printer
(Hp 5610)there was a paper jam and the girl using the printer forced the paper out by pulling it from the front. Part of the paper got stuck in the printer and the gears mixed up. I opened the whole printer serviced and assembled it but printer does not work. All the lights kept flashing with error message (Error:0xd05d01d. Reset Power)
adonscott
  • 106 Answers
SOURCE: paper jam
hi,
sometimes, even we think that the jammed papers were already remove, there might instance that a pieces of paper stuck on the printer. i want you to follow the steps to somehow eliminate that message on your printer screen.
SOLUTION I:
1. press the power ON button to turn the printer off.
2. unplug the power cord from the back of the printer.
3. wait for 1 minute and plug it back in.
4. if you still have that "paper jam" message, continue to SOLUTION II.
SOLUTION II: CLEARING JAM PAPER
1. On the rear of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it.
CAUTION: Do not try to clear a paper jam from the front of the product. Doing so can damage the print mechanism.
2. Gently pull the paper out of the rollers if you see one.
CAUTION: If the paper tears while being removed from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. Loose pieces of paper will cause future paper jams.
3. Replace the rear access door. Gently push the door forward until it snaps into place.
4. Press OK to continue the current print job.
Note: If the issue is not resolved , continue to the next step.
SOLUTION III:
  1. Turn off the unit, then unplug the power cord.
  2. Press in the tab on the left side of the rear clean-out door to release the door. Remove the door by pulling it away from the unit.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
  4. Allow the rollers to dry completely, then replace the rear access door.
  5. Plug the unit back in and turn it on.
This time, try to print something.
Thank you so much.
best regards,
adonscott
Posted on Jul 03, 2008
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
  • 138 Answers
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Posted on Aug 03, 2008
sagarjd
  • 95 Answers
SOURCE: paper jam 5610 hp
Please perform the steps in the following weblink.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00441807&dlc=en&product=441125
Regards,
sagarjd
Posted on Nov 05, 2008
  • 230 Answers
SOURCE: Paper Jam error with no paper ...
Put your hand in and poke at the front and poke all the levers and move things around a bit it sounds like a stuck switch and poking them normaly frees them up.
Posted on May 06, 2009
Paper jam how to repair
In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
Sep 06, 2010 | HP Officejet 5610 All-In-One InkJet...
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
After clearing a paper jam incorrectly
Please check all places and follow all the steps here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125
Thank you
TechSaver
Feb 05, 2010 | HP Officejet 5610 All-In-One InkJet...
HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i clear paper jam with out pulling paper from front
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab54
Jun 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Trying to fax out something and it keeps telling me jammed
Open up the cover over the adf feed. Make sure there's no paper caught in the mechanism. If I recall correctly (don't have one in front of me), the rollers can be lifted out of this one. Try this and make sure you didn't miss anything. DO NOT FORCE IT. If the rollers don't snap out with only a little pressure, seek another way to pull them out, or perhaops I was incorrect.
If there's no paper, you probably have a stuck or broken sensor flag. The feeds use these flags to detect the presence of paper, so if it's stuck, it's detecting paper when there isn't supposed to be, so the printer thinks you're jammed. If you see the flag and it appears to be stuck, use a stretched paper clip to get it back in place. Again, DO NOT FORCE IT, or you could bereak the flag or the sensor.
If the flag appears to be broken, then you will have to call HP if the unit is in warranty. They do not allow ASPs to work on inkjet printers in warranty and you have to return the unit to them. Often, they will cross-ship you a replacement. Call 1-800-HP-INVENT
Jun 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam
MOST HP PRINTERS HAVE A DOOR ON THE BACK SIDE OF THE PRINTER THAT CAN BE OPENED TO REMOVE A PAPER JAM. HAVE YOU TRIED USING THIS TO CLEAN THE PAPER JAM. THERE MIGHT BE SOMETHING STUCK IN THE PAPER PATH THAT IS CAUSING THE JAMS. CHECK THE WHOLE PAPER PATH FROM THIS REAR ACCESS DOOR. OK?
ARCLIGHT1217
Sep 08, 2008 | HP PSC 1110 All-In-One Thermal Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
