Question about ViewSonic VA800 17.4" Flat Panel LCD Monitor
Va800 streaking white after text
  • 585 Answers
This issue presents itself in different ways in this monitor, in the form of smeary video, or color changing from the left to right, or as you indicate, a smear following text. I know this as I own this monitor, and have repaired this myself. There are three 1 mf capacitors, surface mounted on the control board inside the monitor that fail. They are in the RGB input lines, and when they fail they cause distortion of the RGB signals, causing what you see. They are the three caps you will find in a row, spaced maybe 14mm on the board between the VGA connector and the processor chip. I would replace all three, observing polarity markings. You can get by just fine using old-style thru-hole caps, just form and clip the leads and solder 'em down on the surface-mount pads. I highly recommend proper soldering tools for this job though, especially for the removal of the old parts, they don't want to come off unless you can heat both pads at the same time.
Posted on Dec 14, 2008
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
My viewsonic VA800 just started getting all pixillated - does it need to be degaussed?
mitchpowell, CRT monitors need to be "degaussed". No need for that with CCFL back-lit LCD displays. 12fixlouie
Feb 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
Black text has white streaks
You have to clean the nozzle with cartridge cleaner liquid
Mar 26, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
Short, 3/8", horizontal blurs
I posted this answer on another "white streak" question, I suspect this is right:
Jan 15, 2008 | ViewSonic VA800 17.4" Flat Panel LCD...
ViewSonic VA800 17.4" Flat Panel LCD Monitor Logo
164 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
