Question about Cobra 75 WX ST 40-Channels Handheld CB Radio
I am to trasmitt and receive while ignition key is off but when i turn key on i still am able to transmitt but i receive a lot of stastic. I have replaced the antenna and co ax and redone the ground.
    Genius:
  • 1,274 Answers
Hi, my name is John. That noise you hear is probably coming from switch,such as ,seat belt warning,door,light, key switch , exc. Try running your CB wire strait to the battery, and see if it stops. If not, Radio Shack sells a noise limiter that goes in line with your connection, don't know how much. Do you have your noise limiter or noise blanker switch on the radio?...hope this was very helpful....
Posted on Sep 01, 2010
  • 38 Answers
Your problem is simple and will never go away because of the design of that particular radio. I am familiar....best bet is to get another radio and try to refrain from buying handhelds and buy a mobile radio with a good antenna. For under $100, you can have a nice rig. Just stay away from digital readouts......they are a real pain! get a Cobra 29 LTD Classic and NO RUBBER DUCKY ANTENNAS!
"WILDCAT: IN LAURELVILLE OHIO
35 YEARS OF CB SERVICE
Posted on Dec 30, 2010
How to program New key switch 2000 oldsmobile silhouette
Key switch ? key fob ? Transmitter Programming ?
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important: Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
  1. Remove the ignition key from the ignition lock cylinder.
  2. Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
  3. Close all of the doors.
  4. Close the lift gate.
  5. Turn the ignition lock cylinder to ACC.
  6. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
  7. Open and close any vehicle door.
  8. A chime will be heard when the system enters the BCM programming/diagnostic mode.
    Important: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  9. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
  10. Repeat the previous step on each additional transmitter to be programmed.
  11. Remove the ignition key from the ignition lock cylinder.
  12. Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Apr 22, 2016 | Oldsmobile Cars & Trucks
How to program a new alarm remote
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
Hope this helps, I found it online
-Scott
Feb 19, 2015 | 2004 Pontiac Grand Prix
I have already try putting in new batteries and taken out of the clock and the trasmitter and still dont work what can i do now its a SioScan Temperature Transmitter 433 MHz
This type of device requires battery installation in the transmitter first, then a brief wait for the transmitter to begin sending temperature data. Once the transmitter begis sending data, install batteries in the "receiver" and check for temperature display.
Nov 01, 2014 | Home
Pontiac keyless fob
This worked for me...
Important
Sep 02, 2013 | Keyless Entry Remote Fob Clicker for 2003 ...
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
KEY FOB PROGRAMMING INSTRUCTIONS
No Tools Required
Important
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Important
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
I have a problem with opening car doors with remote for 1997 pontiac sunfire. I noticed that when you are in the car and you activate the open and close switch from drivers side the locks at the rear open...
Try this procedure...
No Tools Required
In the event that a transmitter is lost, program the old & the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Program only 1 vehicle remote control door lock receiver at a time. If u program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Sit in the vehicle driver is seat. (actually it’s much ezr from the front pass seat)
Close all of the vehicle is doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body & Chassis.
Open & then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If u do not hear a chime, start again at step 1.
Important
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body & Chassis.
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1997 Pontiac Sunfire
How do I reset a Key Fob for my 2006 Grand Prix. I have a key fob from a different year car that I would like to program to my current 2006 car. I only have one fob for the current car.
No Tools Required
Important
Perform the following steps: Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Important
Nov 13, 2009 | 2006 Pontiac Grand Prix
How do you program the remotes for keyless entry with a 200 pontiac grand am?
No Tools Required
Important
Important
Oct 21, 2009 | 2000 Pontiac Grand Am GT
Can't program keyless entry remote.
Try this,
No Tools Required
Important
Important
Good luck and hope this helps.
Jun 23, 2009 | 1995 Cadillac DeVille
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Cobra 75 WX ST 40-Channels Handheld CB Radio Logo
103 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
