Question about Frigidaire Dryers
I smells hot and squeels - Frigidaire Dryers
    Genius:
  • 1,400 Answers
Hello
Possible bad drive belt.Or motor is getting old.
Remove back panel and check the belt,also clean out any dust or lint from the motor. if the belt is cracked or missing pieces it needs to be replaced.
Posted on Aug 29, 2010
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
It still has a burn off smell it won't come on at 2 and 3 when it goes off it make a sqealing sound sometimes
As far as the smell is concerned ... If you initially burned it on high for a minimum of 45 minutes, the smell should have dissipated. If however, you have recently painted prior to or just after it's installation, it's probably picking up the new paint odor and making it worse. Rug or floor cleaning products will do the same thing. As far as the squeeling noise is concerned, that could be caused by a low pressure problem from your LP tank regulator. If it occurs when the outside temp is well below freezing, more than likely the tank regulator is partially frozen. Soak a bath towel in hot water, ring it out and place it around the tank regulator to thaw it out. Once the gas is flowing freely again, the squeeling noise should cease.
If none of the above remedies your problem, contact ECS Technical Support 800-851-3153
Jan 26, 2011 | Empire ECS HearthRite HB20T Heater
A/c working fine then loud squeel and hot air started blowing, any ideas?
Is your compressor still working, it may have seized up and the belt was the squeel you heard.
Sep 24, 2009 | 2002 Suzuki XL-7
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
High pitch squeeling noise/no picture.
your problem is due short circuit in horizontal section of  tv
your problem & smell is due to horizontal section failure.
in that section
1 flyback transformer & horizontal output transistor might be faulty.
but remember to check power supply is normal other wise it may fail again.
for skilled technician it is not a major problem &easy to fix at fair cost.
good luck.
Oct 16, 2007 | Zenith A36B41W 36" TV
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Dryers Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
