Question about Danby DDW497W 22 in. Countertop Dishwasher
My brother needs the faucet adapter for his DDW396 counter top dishwasher (forgot to take it off faucet when moved). Have the quick disconnect but not piece for faucet. I tried to find it online for him but don't know which one is correct and Danby doesn't seem to have a parts store.
I did the same thing when I moved. I went to Home Depot and was able to pick up a replacement nozzle there.
Posted on Sep 08, 2010
Do I need to replace the adapter for the faucet areator for my portable dishwasher.
Probably. If you didn't discard the package of extra fittings that came with the dishwasher, you may find the correct adapter/aerator fitting in there. Otherwise, try contacting the manufacturer of the dishwasher. Be sure to provide the make and model of the new faucet along with the model number of the dishwasher.
Jan 03, 2015 | Dishwashers
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Dishwasher fills with water when running faucet
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Jan 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Faucet connection
You only need to put back on the steel clamp that fits over the assembly which holds down the shield, the spring, and keeps the 4 ball bearings in place. The ball bearings may be tricky though as they tend to fall out when your putting the assembly back together.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Halfway through the cycle it beeps an E3 code and stops running?
make sure the faucet is on. if it's turned off you will receive the error (err03) code.
Dec 04, 2008 | Danby 22 in. DDW396 Free-standing...
Hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Nov 12, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Danby counter top dishwasher
Yes, it can be, pretty easy 2 hour or so task. My husband did it with the help of a local plumbing shop. Take pictures of the back of your unit and go to a shop, they'll set you up with what you need to do it.
Apr 01, 2008 | Danby 22 in. DDW396 Free-standing...
Maytag performa dishwasher pdc3600awx
Home depot sells the faucet adaptor you need. It is called "Long Dishwasher Aerator" and states 55/64 " - 27 thread. The number on the top left which I suppose is the part number is 36094B. It also has a yellow stick with "2A" on it, which should help find it quickly. It is located in the section where they have all the kitchen faucet aerators etc. Found it easily. Cost was $3.77
Mar 30, 2008 | Maytag Performa PAV2200
Dishwasher problems
First thing to check water hose that connect at back of machine. pull the screen out and clean it. use a pliers. I run my under water then use a q-tip if its clog to clean the rest.
Then pour a cup of vingar in machine and run it.
Oct 04, 2007 | Danby 22 in. DDW396 Free-standing...
Danby DDW497W 22 in. Countertop Dishwasher Logo
532 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
