Audio Shelf Systems
Problem for Audio Shelf Systems
Generic problem for all Audio Shelf Systems
Turntable removal
By davidod on May 08, 2008
the fisher mt6410 turntable does not have a ring lock so it still lifts slightly and the sticks.
Comments:
May 10, 2008
- i actually found the solution. some platters were pressed on lightly so you lift up on the platter and tap on the spindle . the platter should pop off.
Solution #1
posted on May 08, 2008
Somewhat Helpful)
knightstar7
Rank: Wiz
Rating: 79%, 186 votes
Some t/tables have a rubber mat held in place with adhesive. Lift mat around spindle bearing, see if there is a "c" clip. Also if you can remove spindle look for anything that may be holding t/t. There is an outside chance dried lubricant has caused the bearing to stick. Brace the t/t base and with finger tips, lift t/t and with gentle rotating motion, try to lift off
Was this helpful?
Yes
No
Popular Solutions for Audio Shelf Systems
Questions and Unsolved Problems for Audio Shelf Systems
Answer
Does the Sharp CD C602 have a light in the main window?
Answer
Crosley CR66 Everything works except the CD player....I turn it to CD and zero power... zero... (More)
Answer
my sony 771 won t play any sound -- not the speakers because doesn't come through headphones either.... (More)
Answer
Hitachi ax-m110 CD player does not read disks, gives message No-Disk
Answer
Display panel on my lifestyle 5 doesn't work, any suggestions what could be wrong with it ?.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
