Question about Fossil Watches
When the battery on my watch died I took it out to find a replacement and now I have lost it. Do you have any idea what the replacement is for JR8184. Thanks
Best guess is that you require a battery that is equivalent to a Varta V384 or V392. These batteries have identical dimensions ( and output) that are 7.9mm diam and 3.6mm thick. Anyone with a micrometer can measure the vacant "hole" in the back of the watch and give you dimensions of a replacement battery - brand is irrelevant
Posted on Aug 30, 2010
Tip
LOST SOUND AFTER BATTERY REPLACEMENT.
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
Watch battery died. Took out and then lost the factory original battery for my Timex Mens 100 Lap Watch Ironman Watch on way to store. Internal parts to watch don't say what battery number I need. You...
I have a 100 lap Timex Ironman Triathlon Flix watch. It uses a CR2025 battery. It is a thin 3 volt lithium battery. My original was a Panasonic battery. I hope that this helps you, Michael
Nov 17, 2010 | Timex Sports Ironman Triathlon 100-Lap...
I have a Pulsar w861-x002. The battery went dead, so I took the watch to a jewelry store (that also sells Pulsar watches). They replaced the battery, but now the time/year/and everything else cannot be...
I replaced my battery too...same watch same ugly condition where you can't set time nor does the light work.
I do know what the problem is: there was an ultra small copperish spring...about 1/6 the size of the other little wire spring that you have to short with twizers to reset time. Anyway, I lost this part...and even if I found it, I wouldn't know where it goes. I came on-line to find where the missing part goes...but everyone has the same issue as me. any jeweler would loose this parts just like me...it's the master contact the enables power to all the side pushbuttons
Sep 15, 2010 | Watches
I have a 14 k Vicence gold watch. The battery
SORRY but FIXYA has no idea who made it or where they are , might be out of business .
Oct 19, 2017 | Vicence Rectangular Watch
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Watches Logo
102 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
