Question about Nintendo DS Lite Console
Touch screen doesn't work
We have tried everything recommended in the instruction manual, and the touch screen still doesn't preform the adjustment to the contact point on the screen. We touch it and nothing happens.
We've had this Nintendo since december 2007. What can we do?
  • imaluckymom May 10, 2008
    Hi Julianfix,
    As I posted in my problem, I've tried it all. I did go to the nintendo website, and none of the suggestions worked. But thanks anyway. I'm sending it in for repairs or replacement.
    imaluckymom
  • 975 Answers
GO TO THIS LINK :
http://www.nintendo.com/consumer/ , and follow some steps in troubleshooting your DS unit , hope this helps AJ
Posted on May 10, 2008
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
We have a VReader and the touch screen doesn't
Try calibrating the touch screen (means of doing this can be found in the user manual). If, after calibrating the screen the touch screen is no longer responsive, I'm afraid that the screen is "ka-put" and will require a repair or replacement.
Jun 24, 2013 | Cell Phones
Why doesn't my android touch screen work?
it is clearly that your touch screen is damaged.... i recommend you to buy a new touch screen and replace it....
Jan 28, 2012 | Logitech Lands Phones
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
How do i get bass from my iva-d310
To get to the bass settings touch [SETUP] on the source main screen and on the next screen touch [i-Personalize]. Touch [>>] of BASS ENGINE. The screen will change to the Bass Engine setting screen. Touch left or right arrow or [>>] of the desired Bass Engine setting item (i.e. Bass Max EQ, Bass Focus, etc). Touch arrows or the adjusted screen of the selected setting item, and change the setting. When setting is complete, storing in memory is recommended. Touch [RETURN] when finished.
For more information go to manual, page 37 and 38: http://www.fixya.com/support/p199196-alpine_iva_d310_car_dvd_player/manual-2142
Feb 23, 2011 | Alpine IVA-D310 Car DVD Player
How you control your bass
Touch [SETUP] on the source main screen and on the next screen touch [i-Personalize]. Touch [>>] of BASS ENGINE. The screen will change to the Bass Engine setting screen. Touch left or right arrow or [>>] of the desired Bass Engine setting item (i.e. Bass Max EQ, Bass Focus, etc). Touch arrows or the adjusted screen of the selected setting item, and change the setting. When setting is complete, storing in memory is recommended. Touch [RETURN] when finished.
Feb 08, 2011 | Alpine IVA-D310 Car DVD Player
The touch screen has stop responding. All the other buttons on the control panel work and change the display on the panel accordingly, but you cannot select any options from the touch screen. Any...
PROBABLE CAUSES:
1. The control panel adjustment is incorrect. This adjustment will shift the position of the touch sensor of the LCD unit. Perform the following steps:
a. Hold the Help key and turn power ON.
b. Touch selection #10 (control panel adjustment) on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
Two + (plus signs) should be visible on the screen.
c. Touch the + at the upper right lightly with a touch pen (something with a round tip which is made of resin is recommended as a touchpen). Check the coordinates displayed in the top line at the top of the screen.
d. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
e. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
f. Touch the + at the lower left lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
g. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
h. Turn the machine OFF to store the adjustment. Turn the machine ON normally and check operation of the touch screen.
Dec 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
Aug 08, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Htc locked touch screen mal functioning
Try mDesktop for remote control from your PC to unlock the phone.
Apr 10, 2009 | HTC Touch P3450 Smartphone
Nintendo DS Lite Console Logo
603 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
