Question about RCA (DVDCP33) Media
Kingston DTI/512 I have problem with my Kingston DTI/512 flash drive. When I plug in the pc detect and I can see it when I open My computer, but I cannot epen it. It say that cannot fine the drive. Some PC it siad the drive is not format when I try to format it said cannot format. Help me please because I have some document on it. ALSV
  • naveedbhutto Oct 30, 2008
    my USB have the same problem and i am unable to format also.
    President:
  • 1,257 Answers
If you are unable to open it ,there might be a virus in you flash drive which is causing problem .
Solution:
Select the flash drive and right click .now select autoplay, a dialogue box will appear ,now select open to open it..
if you are unable to do this .
open my computer ,in the address bar ,click on the downn area button in address bar and select flash drive to open .if this also fails you have to format the flash drive ..
Try this in other pc if you are unable to do this on your computer ..now if you are getting same problem ,format it.
right click on it >select format >and format it to remove virus ...
If this answers your question please rate this as fixed.
THANKS.
Posted on May 08, 2008
My pen drive is not detected.
The best thing to do is to try it in a friends computer, remember to scan it with an anti-virus program if it is detected. Otherwise it is possible that the USB flash drive has malfunctioned or needs to be reformatted. Hand it over to a PC technician maybe he/she can recover the information on it. Might be time to purchase a new one as they do wear out.
damnor01
Nov 15, 2010 | Kingston Combo 4GB DTI USB and 4GB...
Need driver
Hi. Acually sir your usb flash drive is a plug and play device. Just plug it in on your computer and it should automatically be detected by your computer if you're using Windows XP, Vista or Windows 7. If you're pertaining to the Windows 98 driver you can download the driver on this link http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DTI_HS , just click the DTI.EXE then it will let you download the driver for your usb. Goodluck!
Jun 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB DTI/1GB Malfunction error
your USB Flash Disk is damage already, you need to be repaired your Flash Disk to read again in your PC.
Jul 22, 2009 | Computers & Internet
My 32GB KINGSTON FLASH DRIVE IS DEAD BARELY AFTER
I had such an issue with my 16GB Kingston it just died after 2 month. But usually it comes with at least 5 year warranty. So I returned mine and got new one instead. My luck that I had my files backed up. Try to change your kingston if it's completely undiscovered by your PC. But try it on another PC or Mac first. Good luck!
Jun 01, 2009 | Kingston (SDCZ2-512-A10-KT)...
USB-Flash Drive Problem?
In The BIOS setting , there is a setting for making the USB drive High-speed or full-speed. Try to change it and the check, also enable external/removable drive option in the chiset setting. Finally if nothing help, try defaul settings and plug in yourUSB drive while connected to the net. If it responds th same way then try full format of the Flash drive, remove the hardware on on plugging it back open "add new hardware" and let it load automatically, even via the net for the optimum driver. Also visit their web site and do the troubleshooting steps if all the above fail...sodeep
Mar 22, 2009 | Computers & Internet
Yes, Thease Flash drives are FAKE... Please go through the below blog and try to recover your Flash drive actual capacity.
http://thefake32gbs.blogspot.com/2009/02/fake-32-gbs.html
Mar 04, 2009 | Kingston (SDCZ2-512-A10-KT)...
Move data from one computer to another with kingston 8gb data tra
When you plug in the Flash Drive to your old computer, it will show up in My Computer probably as Removable disk or "Kingston Data Travler". You want to open that link up and drag whatever files you need into that folder. After doing so you put the flash drive in your new computer and repeat the process except you drag the files out of the folder and onto your desktop or a folder of your liking.
Jan 31, 2009 | Kingston (SDCZ2-512-A10-KT)...
Not detect
may be its due to the virus in ur pc...try in other pc... or go to an secured pc and reformat it...if the light doesn blink even after it shows its detecting then u have to contact the service center or where u bought..
ne other probs do tell me..im always here 4 u, n plz plz plz do rate me.. cya
Apr 15, 2008 | Kingston (SDCZ2-512-A10-KT)...
Problem with kingston DTI/4GB
Help me please!!!When I insert my 2GB kingston USB into my computer I go to "My Computer" then I go open it but it say "Choose a program to open the file"!!!What should I DO???Please help......Usually I can open it one but now suddenly cannot(I don't have the program that can be used to open the USB)
Apr 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
W98SE Driver for Kingston 1.0Gb DataTraveller Flash Drive
The people at your local computer shop are wrong but, Windows 98 should at least recognize the USB thumb-drive and ask for drivers.
I would remove all the USB Controllers from within Device Manager and restart; allow Windows upon restart to reload the USB Controllers; then plug in the drive and see if Windows at least recognizes and then install drivers.
It seems only the DTI/XX, KUSBDTE/XX, and DTII/XX support Windows 98.
Dec 04, 2007 | Microsoft Windows 98 for PC
RCA (DVDCP33) Media Logo
396 people viewed this question
Top RCA Electronics - Others Experts
ray gallant
Robert A. Watson
Robert A. Watson
Are you a RCA Electronics - Other Expert? Answer questions, earn points and help others
