Question about Lanier UNKNOWN
How do I remove fuser lamp? or trouble shoot SC546 trouble code on Lanier 5622 copy machine
  • exlead Sep 03, 2010
    Purchased service manual $16 and ordered 2 thermisters $40.
Cogz
  • 1326 Answers
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
  • 990 Answers
SOURCE: Have a Lanier 5518 with a sc546 code, fuser
Hello sir; According the menual said, that's thermister open or power supply board, but before go that far why don't try to do a reset, steps as follow;
Press "clear mode", "107", then pres and hold down "clear/stop" key, then choice "copier SP" then enter "5810" press enter, select 1, then press"R/#" key and "original type" key at same time to reset, try it and let me know the result. after reset just turn power off and back on.
Posted on May 09, 2009
Testimonial: "Thanks for the help:)!"
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Posted on Jul 29, 2009
  • 2072 Answers
SOURCE: Got a function code SC322 on lanier 5622 copier.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
Posted on Sep 15, 2010
  • 44109 Answers
SOURCE: What will fix a code SC546?
The replacement fuser may have failed.
Posted on Jul 10, 2014
Jul 10, 2014 | Lanier Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Jul 29, 2009 | Lanier Office Equipment & Supplies
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
Have a Lanier 5518 with a sc546 code, fuser problem but will not reset. What section of the fuser is bad. Savin model match? A???
May 09, 2009 | Lanier Office Equipment & Supplies
Fault SC546
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Jan 12, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
TECH SUPPORT
Possible solution: Remove fuser cover, remove carbon buildup from thermistor.
I had to replace the fuser unit but it had 180,000 copies - service is 120,000
Aug 01, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
Alun Cox
quennie732
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
