Question about Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive
The USB is detected but the required driver is missing. I dont know which driver to install for this problem
    Master:
  • 645 Answers
Normally the driver is preinstalled with the operating system.
If there the driver is not getting installed properly, you will have to remove the drivers and let the OS reinstall it once more.
Can you tell me which OS you are using?
Posted on Dec 14, 2011
Want activate internet
what do you mean activate internet? did you mean activate OS? internet usually is auto-detect as long as you have all the required drivers. try typing devmgmt.msc in run command and check if you have highlighted part means missing driver. perhaps you dont have wlan driver installed.
Dec 01, 2013 | HP Pavilion Computers & Internet
I think, i am having a usb port malfunction. i just formatted my lg-ibm xnote lm50a with xp3 and installed all the drivers but all my usb ports don't function. it does not detect printers and mouse...
Have tried installing the CHIPSET Driver for the Motherboard?
Check the device manager for any bang on the devices meaning either a driver is missing or a wrong or incorrect driver is possibly installed, unless a REX "x" is foung beside USB hub then that would mean that is it busted or damaged.
but it is unlikely to have a USB hub/port to be busted unless physically, install the chipset driver and check again make sure you restart the system after installing the CHIPSET driver to make sure that it is properly installed in Windows and that it will detect the USB ports in device manager.
Oct 30, 2011 | LG X-Note LM50 Notebook
Wireless USB Moderm not detected on insertion into USB port of laptom. alert says' localizing file missing.' cannot connect to internet
You will need to uninstall the drivers for USB ports and re-install the drivers. (again drivers for USB ready to use ports, but not wireless modem.)
some times files from drivers are missing for USB port (Through Motherboard).
Once you are done with the re-installation it will be done.
Jun 15, 2011 | Computers & Internet
I have a lexar 2gb jd firefly usb drive and i dont know hoe to install the driver for it. Please help me!
You don't need to install any drivers for it, windows should detect new hardware and install the drivers that it already has for it. If your system isn't detecting new hardware when your plugging it in, then you might have an issue with your USB ports on your motherboard. If thats the case then go ahead and try hooking up like a USB keyboard or USB mouse. If it recognizes those then you know your ports are fine.
If your ports are fine and your USB firefly drive isn't being recognized, then your USB firefly drive is bad.
Jun 30, 2010 | Computers & Internet
Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
Apr 13, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
USB Hard Drive wont open
Make sure you have installed the software drivers first before connecting the USB hard drive. USB is Plug and Play, and when you connect hardware that requires drivers to be installed first, it will not function correctly or not work at all sometimes..
May 21, 2009 | Fantom (FDND250) 250 GB USB Hard Drive
My A4TECH PK-636MA WEB CAM WON'T WORK AFTER INSTALLATION
remove all previous web cam drivers from the pc ...
reinstall the driver ...and after you plug it ...let the wizard to search for the driver and do something that seam like reinstalling second time ...
if it will gave you some errors for missing files (example: missing dll.d50 or something like this ) just click browse and locate the file manually from the installation cd ...or from the folder where is installed it depends...sometimes I dont know why ...just do not see some files...maybe its something about compatibility ...or ...OS )
if after this is still not working ...see maybe is not a webcam that will work with your operating system ...some dont work on vista ...or windows 7 ...
Mar 19, 2009 | A4tech G-Cube Cosmo-tini notebook webcam
I have just purchased an Enter 5 Megapixel Webcam but dont know how to install and i dont have a CD for the same to install, can you provide me with the link from where i can download the same to install...
It's a 'Driverless' webcam. No Driver install is required, plugit in and XP will detect it, do a behind the scenes usb install and it'll be up and running. Not sure about Vista, though.
Hope this helps
Chris (ziraffa)
Jan 15, 2009 | Creative Labs Instant Webcam
Usb Driver For Huawei SmartAx Mt882 for win XP professional
Windows XP Professional doesnt require USB Drivers, these Driver built in Windows XP professional
or there already present in ur system..........
so go ahead connect anything to ur usb port(like digital camera, mouse, pen dirve, flash driver , memory card reader,..portable harddisk , digital cameras)
when u insert any of the component(for eg: pen drive) in to the usb port OS will automatically detected these devices and install USB Drivers.... dont worry... about this  and be rest assured....OS will do the work for u...............
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Dont know how to work webcam
plug the usb cable of your webcam to your pc's usb slot, whe windows detects the new hardware insert the cd driver that came with your webcam. then install the additional applications on the cd. restart your pc if it requires you to do so. otherwise open the application of your webcam and try it out. have fun!
Oct 28, 2008 | Acer Aspire 3610 Notebook
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
82 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
