Question about Kenmore Refrigerators
Model 596.50003100 freezer temp lite is blinking and rising
  • 1462 Answers
SOURCE: kenmore elite bottom freezer 596 serires
+4 degC for fridge and -18degC for free3zer
Posted on Sep 07, 2008
  • 103 Answers
SOURCE: temp is rising in my freezer (0 to 10 in a few minutes)
Hi: Is it so full you blocked the vents in the back? It's possible it was going through a defrost cycle when you checked and it naturally spiked in temperature. Don't open the door every few minutes ( everybody does it) as you will dump the cold air out of it. Call Service if it isn't one of the simple things get it rolling, as it would be serious. If I'm right call and cancel the service call. I hope your problem is simple and cheap, Jeff
Posted on Jun 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: model 596 50392001 side by side panel between
This is uaually caused by the condenser fan not running. It's underneath the fridge behind the cardboard backing. Should be running when compressor motor is.
Could be caused by ice buildup on coils behind the back cover inside the freezer. This would be an auto defrost problem.
Posted on Jul 10, 2009
HIRAM517
  • 59 Answers
SOURCE: fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Posted on Aug 19, 2009
tunde007
  • 2382 Answers
SOURCE: Our model is freezer on
Hi, these are the possible cause of the problem, you have to check one after the other to proffer the solution.
  • Vents between fridge and freezer sections are clogged with ice. Warranty guy told me to unplug 24 hours, replug and everything should work out.
  • Fautly thermostat.
  • Clogged/dirty evaporator coils (underneath in newer models, on back in older models).
  • Bad "Adaptive Defrost Control Board", Google it, it's an easy fix, about $35 on ebay, just make sure you
Posted on Sep 06, 2010
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
I have a Prestige fridge/freezer model prt325ffcs, 18months old, and the problem is that the freezer compartment is not remaining cold , the super freeze function works reducing the temp. to -25 , but as...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | GE Refrigerators
Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Jul 24, 2010 | Samsung RB215LASH
The fan in my freezer was making a loud noice for several weeks as if it was having a hard time starting & now it is not working at all. The temp. in the freezer still remains the same. What will that...
Without a freezer fan the temp. in the frig will rise and the milk will spoil. After more days the temp. in the freezer will rise as well. Without a freezer fan the air is not moving, so naturally the the evaporator will ice up. Worst case the motor will smell like burnt. the frig will suffer 1st then the freezer. someone can get sick be careful. hope this was helpful replace the motor
Mar 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
Fridge temp goes up and ice forms in fridge
Aug 19, 2009 | Samsung Refrigerators
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
