RCA D52W20 The T.V. will not turn on. The TV will click three times and then the power will turn off. When the back panel is off you can hear the clicking noise coming from a small white box with copper wires inside of it. It's on the left handside when facing the back of the T.V. Do you know what the problem is thanks.
  • daystar917 May 09, 2008
    The solder looks ok but I'm no expect. Let's say it is the flyback how much do you think this repair would cost to have a tech come and fix it. I'm trying to decide if it's worth fixing or not. Thanks for the help
  • daystar917 May 20, 2008
    Thanks so much, I ended up just buying a new tv now I need to sell this one =( but thanks so much for your help!
  • 8,617 Answers
Check on the bottom of that coil with the copper wires. the solder may be de graded thats a common issue with that chassis if that doesnt help you will most likely need the flyback as thats the second most common part that will cause the symptom youre describing. Let me know if I can assist you further.
Posted on May 08, 2008
  • Sonny Berry
    Sonny Berry May 09, 2008
    a tech will charge about 120.00 for the flyback and possably another 250 to 300 hundred for the service call and labor. you may want to call and have them give you an estimate on replacing the flyback. Or if you can solder, I can post a link where you can get a new flyback for less than 50 dollars and they provide free tech support so you can do the repair yoursel. If you would like the link here it is you would need flyback number 259296 for your model TV
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry May 20, 2008
    which part of the country are you in as I am always buying dead projection units. Anywhere close to NC?
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shows some sines of power but dosn't turn on.
U MUST HEAT IT UP BEFORE IT WILL TURN COMPLETELY ON U HAVE TO HEAT UP THE CURICIT BOARD AND THE BACK OF THE T.V. BEST WAY TO DO SO IS USE A HAIR DRYER AND TAKE OF THE PANEL IT WILL WORK FASTER.
Jun 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52w20 TV WON'T POWER UP
I had the same problem and it was the cp150. It cost me $2. Easy to change. I would look in the back and see if any of the capacitors are popped or bulging out on the top.
Jan 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
I have the same problem; I push the power button green light comes on tv clicks but doesn't come on.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Just moved tv and now will not power on. i do hear click noise in speaker ,
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Jan 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO picture no sound
blinks three times?, do you hear any clicking?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
