Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
My polaris280 runs in circles and the tail does not want to stay behind the polaris
  • 22 Answers
There are several things that may cause the unit to run in circles. #1 never roll the hose when the unit is out of the water. Infact every year you should remove the entire unit from the pool and lay the hoses straight on the deck in the warm sun light. 1 to 3 days is usually enough use rocks if you need to in order to force th hose to stay straight. the hoses have memory and when you roll them up and lay them outside the pool this starts the problem. you also need to see if all three wheels turn in sequence. you can grab ahold of the single wheel on the left side and be sure it spins forward and backward without resistance. additonally the right front wheel should spin at the same time. there is a gear that runs between both front wheels and when the booster pump runs the gears spin and turn the front wheels. the back wheel turns from the tension placed on it by the small wheel between the two tires on the right side. over time the metal gears can wear out the plastic grooves inside the large wheels. if there is too much wear on one of the wheels you can remove one of the front tires and swap it with the back tire since it does not need the gear or grooves to turn. another issue is the directional jet located under the fitting the whip hose attaches. this uses the water pressure to direct the unit in different directions if the nipple is pointed to 12 noon this causes the unit to climb more 6 am will limit the climbing the urge. when pointed to the left it cause the unit to vere to the right and vice verse. 808-871-POOL
Posted on Sep 22, 2010
Water comes out of the tail of polaris 360, but tail does not sweep.
check the filter in the wall of the pool where the Polaris line hooks up, it got a small filter in it. you are running it on low-pressure that's why it not sweeping, could also be a plugged impeller on the booster pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 21, 2017 | Polaris Pool & Spa
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
The tail of the Polaris comes out of the water surface some times and sprays a ten foot jet of water. I would like to weigh it down some more to prevent this but at the same time not limit its movement.
That is normal-- when polaris runs up the side and heads down the tail follows and there you have it. You know the saying if you cant stand the heat get out of the kitchen-- well if you cant stand getting sprayed stay in the kitchen. Just kiddin the kids seem to enjoy the machine spraying everybody
Nov 20, 2012 | Pool & Spa
My polaris is doing circles. it appears the single wheel doesnt move like it used to
i've just discovered i have this same issue with my polaris 3900. the machine is less than 3 months old. there is a small metal "gear" in the wheel hub just behind the blue "hub cap". a single screw holds it on the axle. it appears that the gear has worn the out around the hub causing it to slip and not be able to drive the wheel.. it appears that the solution would be to buy another wheel.
Dec 31, 2010 | Polaris 3900 Sport Pool Cleaner ()
My polaris runs but there is no suction. Any recommendation?
Inside the part where the bag clicks onto the large circle outlet on the top are two little valves. Sometimes these get clogged by algae. Use a thin wooden skewer to poke the algae through then replace your line hose onto the pool return. Everything should work now.
Apr 16, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
1,963 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
