Question about Kenmore Dryers
Heats up occasionally, - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
DFS-550-29 REDUCED EFFICIENCY
sounds like the heating element is going bad..its probably intermittant..
Jan 08, 2014 | Duraflame DFS-550-0 Black Metal Electric...
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Water entering via rear heat vent
looks like if its not antifreeze u might need your windshield sealed or if its antifreeze u need a heater core
May 10, 2010 | 1998 Chrysler Cirrus
No heat
This depends on the actual model. But it usually boils down to A. A defective heating element, B. A thermal fuse, or C. A defective thermostat. And sometimes the breaker (or fuse) has tripped on one side. Occasionally a wire burns off too. First reset the breaker by turning it off and back on. If it still won't heat, the problem is within the dryer as above.
Feb 24, 2010 | Maytag Dryers
Heater does not give out heat all the time
possiblt thermostat, how bad was the cooling system before it was serviced, recmd replace thermostate first, if you still have problem, reverse flush heater core to remove settlement from heater core
Jan 22, 2010 | 1994 Buick LeSabre
No consistent heat
make sure it has plenty of coolant in it if it is low the heater wont work. is there any water in the passenger side floorboard
Nov 13, 2008 | 1987 GMC Jimmy
2001 Grand Caravan no heat and occasional over heating.
depends on the engine....a 2.4 requires the removal of the timing belt......on a 3.3 /3.8 the water pump is on the passenger side close to the fire wall.look for an orange or green coored residue in the vacinity of the pump....i would bet its leaking
Oct 04, 2008 | 2001 Dodge Grand Caravan
Blows cool air
This is normal. To maximize the units efficiency the fan continues to run until all the heat from the coil is pasted to the circulating air.
May 24, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
