Is it Samsung HC-R4755W rear projection tv or nay other model?
Is it power indicator red light that blinks 6 times on tv front?
Let me know to diagnose possible cause of problem.
Thanks.
OK, blinking red light on tv front shows that tv got problem in either deflection section or convergence output chips gone bad. Below image shows deflection board and convergence output chips location in tv, let me know if you are handy person and need schematics to find out defective part in mentioned section and if you are not comfortable with working in tv circuit boards then local tv repair shop will help you to get it fixed.
Thanks.
Yes, deflection board consist of power supply, convergence output section, deflection section etc.
Below is close up of deflection board for easy understanding. It also calls Sub Board.
Thanks.
OK, no problem
I hope board replacement will solve the issue.
Thanks.
Part number would be written on circuit board in tv and since its an old model so you need to search it on ebay or local tv repair shop.
Trusted sites like partstore.com has no more stock of parts/ boards for old models.
It is the red power light on front of tv next to power button.
Yes it is a rear projection samsung
If I replace the deflection board will the conv. chips come with the new board. Is the deflection board also considered to be to DLP power supply board. I found one one Internet for $169.00.
Thank you for all your help so far.
Ok thanks.... Guess I will just change that entire board and see what happens. I will let you know the out come of this problem. Thanks for your help.
I want to be sure I get the correct part. Would you have a part number for the deflection board assembly. Even a possible trusted site that I can order one from.
