Question about Dryers
Can we vent our dryer(model#WED8500SRO)down through the floor 12 ft. north and come back up and outside?
  • 1,073 Answers
Not too much duct legenth
Posted on May 08, 2008
My estate dryer model #eed4400wqo
I suppose you want to clean the lint vent to outside. Clean out the filter first by removing the manual filter and pulling off all stuck lint. Try this link to clean the vent:
How to Clean Clothes Dryer Vent
Feb 12, 2015 | Estate Eed4400wq 29 6.5 cu. Ft. Electric...
Hi, our outside vent keeps freezing, ant suggestions on this issue? Thanks for your time.
Add a 12" piece of pipe elbowed down if possible. Also make sure the pipe is sloped back to the furnace 1/4" per ft.
Jan 11, 2015 | Heating & Cooling
Clothes take long time to dry
A dryer with heat but long dry time will always be an issue where the moist air is not able to evacuate effectively.
This could be a restriction in the vent hose (smashed or clogged), blockage at the outside exit (lint build up or a bird's nest), an inordinately long run of vent hose (more than 12 feet) to name a few.
Mar 16, 2014 | Samsung DV422EWHDWR 7.2 Cu Ft Capacity...
Dryer vent duct
The vent pipe codes are based on the fact that the blower in a typical gas dryer can only 'push' a certain volume of air through a certain sized duct for a certain number of feet. Reduced volume of airflow means higher temperatures thus higher risk of fire.
First option ... is your dryer anywhere near a side wall, which would allow you to shorten the total length of duct required to reach the outside to something less than the 14 ft code limit ?
Second option ... upsize the standard 4" dryer exhaust duct to 6" to compensate for the 30ft length
Either way, in the absence of an external forced draft booster fan ( a.k.a. 'power vent' fan ) you should be using metal exhaust duct not plastic.
Jul 28, 2013 | Whirlpool Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Need height from floor to dryer vent outlet for installation of dryer vent
It depends on what floor you are on. If its on a second floor you can put it wherever, but if its on a first floor, its once you vent outside, it needs to be 12 inches from the ground to the top of the vent hood. Check with your local code officials for any codes specific to your municipality.
Aug 03, 2009 | GE DBXR463EDWW Electric Dryer
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
GE Dryer model DDE5700GCLAD
Your dryer is exhibiting symptoms of a restricted/plugged exhaust vent. Remove the vent tube from the rear of the dryer and inspect it for restrictions all the way to the outside vent hood,(including the vent hood), i.e., lint build up/water retention, pinched-off, too long, animal nest, etc. Also make sure your lint filter is being cleaned after each load.
A blower malfunction could also cause your symptom. Do not overload the dryer as this also can restrict air flow.
Most dryers can only be vented 10 to15 ft. and should be cleaned twice a year.
Always utilize the shortest distance/shortest vent concept.
Jul 06, 2009 | GE DVLR223 Dryers
Low heat
hi. thanks for the question. Pull dryer away from wall. lay dryer down. front on floor. remove back panel ,clean all lint. remove air duct on the left . clean all lint. check venting to the outside. thanks the appliance doc
Oct 03, 2008 | Roper Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
