Question about Ovens
I own an Admiral Gas range, Designer Series, purchased at Montgomery Ward in 1993, Model No. 68-02563001. The oven and broiler only heat up intermittently. I need an owner's manual. Can you tell me how to get one? Thank you so much.
  • tchrkaren Aug 29, 2010
    Thank you for your advice. How can I get an owner's manual for a 1993 Admiral Designer Series gas oven with an electric ignitor? I really want it. Thanks!
  • Ovens Master
  • 8,220 Answers
I looked up the model number you posted. Could not find it. You stove either has electric ignitor or pilot light. If it has a glow bar and the ignitor is glowing then it could be weak and that would cause intermittent ignition. Simply changing out the ignitor would fix it. If your stove has the pilot light then you must replace the gas valve. It has a thermocouple in it made of copper and nickle alloy. The heat generated from the pilot holds the bimetal inside the valve open. You can try cleaning around the pilot and reposition the thermocouple in the flame. If that don't do it you gonna need to replace the safety valve.
Posted on Aug 29, 2010
  • Dan Webster
    Dan Webster Aug 29, 2010
    I don't see it happening.
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
119 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
