Question about Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Chuck doesn't turn - Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
I can't release the bit from the chuck.
If it is jammed then hold the bit in a vice and try to knock the chuck off with a cold chisel or suitable piece of brass. then you can remove the chuck screw and replace the chuck. You should not be able to see the bearings underneath.
Jan 27, 2013 | Black & Decker 18 Volt Cordless Drill...
Where can I find a replacement chuck key for a Delta 11-950 bench press?
No you don't have to buy Delta's chuck key. MOST drill press chuck keys are very similar but if you do order another companies key and it doesn't fit, you may be stuck with it. If you have a local tool repair center that carries keys you can try one and if it don't work, return it.
The Delta part number for your chuck key is 1313104. It is avaliable from Dewalt (they own Delta) on their service website at http://servicenet.dewalt.com. You can also get it at aftermarket sites like www.ereplacementparts.com for only $11 plus shipping.
Sep 15, 2012 | Delta Machinery Drills
How do I repair stuck chuck
Sometimes it just needs some lubrication inside where the ball holds onto the bit. If that doesn't work, you need to replace the chuck pieces. Often times they come in a kit. The plastic sleeve may need to be cut or broken off.
Apr 07, 2012 | Drills
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
Chuck on ingersoll rand air drill doesn't turn even without air pressure
pull it apart and check bearings and fibre blades check that they are not cracked or jammed from dried lubricant.
Oct 02, 2011 | Ingersoll Rand Ingersoll-Rand 1/2" Heavy...
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do we get the chuck to stay on, has 4 ball bearings and slots but won"t stay in place.
You twist the chuck counter clock wise while pushing down on it. It will not go on if you rotate it clockwise. Must be COUNTER CLOCKWISE. If this doesn't work then the bit sleeve in the chuck is worn too much and needs repalced. You remove the chuck by rotating counter clockwise and pulling up on it.
Jul 08, 2010 | Bosch 11236VS Rotary Hammer
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Milwaukee 1670 1 Drill 1/2 900 Hole Hawg Logo
41 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
