Question about Ovens
WHAT DOES THE F1 code mean on the Amana Big Oven? How do you reset the code? We did try to unplug it for 20 minutes and then retry with the same results
SOURCE: dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Posted on Sep 05, 2007
Krazytech
  • 725 Answers
SOURCE: F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Posted on Jun 04, 2008
  • 116 Answers
SOURCE: What does F1 mean on the magic chef oven?
The f1 error means the something may be wrong with the touch pad on the oven
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards
Dont forget to rate this solution
Posted on Sep 26, 2008
docjohn174
  • 943 Answers
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Posted on Dec 18, 2008
I have a frigidaire wall oven showing E r r f1 what is wrong no manual
Typically error code F1 could indicate a variety of issues. The wall oven could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the wall oven by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately
Nov 19, 2012 | GE Ovens
What does err F1 mean?
Hello - Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Getting F1 code on my acf4225as Amana big oven
The f1 code code means a button on the touch pad is shorted,you can push clear and the F1 will go off but if it comes on again within 30 minutes the touch pad will need to be replaced
Jul 28, 2011 | Ovens
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Ovens
MY AMANA DROP IN OVEN IS SHOWING A F1 CODE ON THE KEYPAD. IT KEEPS ON BEEPING AT ME. WHAT DO I NEED TO CHANGE??
F1 code means a shorted keypad. Replace the membrane or control, depending how it's available
Jul 14, 2011 | Amana Ovens
Im getting F1 in my Amana Big plus oven
he "F1" fault code indicates an error in the electronic oven control circuitry. The failure is most likely the electronic oven control board and a slight possibility of a faulty oven temperature sensor probe.
Jan 26, 2011 | Ovens
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
Hi.
Regards.
Mar 02, 2010 | Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Ovens Logo
127 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
