Question about Garden
I have a homelite chainsaw xl but i do not know what size chain it takes how do i measure for a new chain
    President:
  • 2,220 Answers
The chain pitch, gauge and number of drive links must all match to function safely. The following links should answer any questions you have (new chains often stretch quite a bit; please keep an eye on the tension).
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Oregon FAQs
http://www.oregonchain.com/pro/service/faq.htm
The easiest and often least expensive method is to take your existing chain (needed for a pattern) to a local chainsaw retailer (not big box store). Once you have these a chain may often be found in a local home center or hardware. Chains in these facilities are usually the least aggressive available. If you have some experience and utilize PPE you may find a chain with a higher possibility of kick back may be more satisfactory.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 30, 2010
  • 487 Answers
Hi, all you need is to count the number of blades. To do this I take the chain off, lay it on a flat serface and count them in two's. Once you have this its just a case of ordering a new one.
Posted on Aug 29, 2010
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
What size of file do i use for a homelite supermini chainsaw chain that has the number 25 on it?
hi there gmlysyshin
if you measure the distance between 3 chain rivets ______ then divide that by 2 to give ______
if this figure is 0.250" your chain is a 1/4 pitch chain in which case you will use a 5/32 file
to sharpen this chain this file is also used on a 0.375 ( 3/8 lo pro chain )
cheers hope this helps
pauly46
May 28, 2011 | Homelite Garden
I have a very old chain saw that was given to me. No paper work on it. how do i measure to get size to get a new chain for it?
In most areas there are usually a number of shops that deal with chain saws. Just take the chain in and they can usually sell bulk chain and will cut it to length and put on the master link for you. That's usually better than trying to figure out what size/model to purchase from a hardware store.
Mar 20, 2011 | Homelite Garden
Decompression valve for Homeliye XL-700 chain saw.
With the age of the chainsaw and the scarity of available parts, it would be major undertaking to even attempt to install a decomp valve into this chainsaw and the result could end up ruining the saw for good.
If I might make a suggestion that you either sell this, as there are many collectors of classic chainsaws such as the XL-700 and you might do better with a newer saw that is easier to start and use.
Either that, or just accept that starting these older saws are more difficult.
As to the C.U. rating for this saw, it is a 4.7 Cu. Inch displacement.
Here's an online manual wih a parts breakdown and exploded line drawings for the XL-700, in case you want to tinker with the saw.
http://www.scribd.com/doc/7283163/Homelite-Xl-700-Xl-800-Ipl
Hope you found this Very Helpful - Best regards!
Aug 18, 2009 | Garden
Homelite XL 101, what are cc's?
cc stands for cubic centermeters..It is a measurement of the chamber that the piston resides in when totally expacted
May 09, 2009 | Homelite Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
