Question about GE Nautilus 24" Built-in Dishwasher
The soap dispensser will not lock in place. - GE Nautilus 24" Built-in Dishwasher
  • GE Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
Replace bellow seal
Hello.
1 Unplug the power cord. Pull the Whirlpool Duet away from the wall. Remove the screws at the back of the machine using a Phillips screwdriver. Remove the top panel from the machine and set it aside.
2 Remove the soap dispenser from the front of the machine by pulling it out and depressing the button at the back to release it. Remove the soap dispenser bracket retaining screws, using a Phillips screwdriver. Pull the dispenser bracket out of the washer.
3 Remove the retaining screws from the control panel with a Phillips screwdriver. Release the locking clips and flip the control panel on top of the machine. There is no need to disconnect the wiring harness. Open the washing machine door and remove the retaining screws from the door latch, using a nut driver.
4 Remove the outer retaining spring from the bellow seal using a pair of needle-nose pliers to grasp the loop and pull it out. Peel the bellow away from the door opening, using your fingers. Push the bellow seal inside the machine after you release it from the door opening.
5 Lift the front of the washing machine and put a wooden block under it.
Remove the retaining screws from the bottom of the front panel using a nut driver. Remove the wooden block from under the washing machine and lower the unit back to the floor. Remove the screws at the top of the front panel with a nut driver. Pull the panel away from the machine and set it aside.
6 Pull the old bellow seal from the machine. Unplug the white and black hoses from the old bellow seal . Remove the spring clamp from the bellow and throw the old bellow seal away. Rub liquid laundry soap on the groove of the new bellow seal. Push the new bellow seal onto the washtub with the opening for the hoses at the top. Push firmly until it is on tight.
7 Install the spring clamp on the new bellow seal into the groove using a Phillips screwdriver. Plug the black and white hoses into the holes at the top of the bellow. Be careful not to damage the bellow seal. Place the front of the machine on the frame and install the top screws using a nut driver. Push the door latch through the hole and install the retaining screws.
8 Press the bellow seal into place around the door opening and install the spring clamp around the perimeter of the bellow. Lift the machine and place the wood block under it. Install the bottom screws with the nut driver. Remove the wooden block and place the machine back on the floor. Put the control panel in place and lock the retaining clips.
9 Install the soap dispenser bracket and the retaining screws using a Phillips screwdriver. Install the retaining screws on the control panel. Place the top cover on the machine and install the screws with the Phillips screwdriver. Plug in the power cord and push the machine against the wall. Install the soap dispenser drawer and push it all the way in so the tab locks into place.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have a troy bilt 220 lb Briggs Stratton Put the clear tube into the gallon of soap, but will not draw. Also, how do I remove the nozzle to attach the low pressure nozzle to apply soap solution?
It won't draw soap unless you have the low pressure nozzle on. It can be replaced by pulling back on the slip collar then pulling out the nozzle. The new nozzle is then put in by again pulling back the slip collar and sliding the new nozzle in, making sure the collar goes all the way back and locks into place.
Jun 19, 2011 | Garden
The dishwasher completed it cycle but didn't use any dish soap and didn't clean the dishes.
It appears that, the soap compartment box did not open during the wash cycle. First check that whether this is the problem. If water flow is good and you are convinced that, the wash has taken place without the soap then, check the soap box relay latch ( if you can do it yourself.)
If this is not possible you have take the help of the service provider authorized by the co.
You can keep soap in a small cup and place it in the upper tray in a suitable place and run the wash till the repairs are attended!.
Oct 05, 2010 | Maytag Dishwashers
Too much foam in dishwasher, accidentally placed a hand soap dispenser in dishwasher foaming all over the place
Scoop out as much suds as you can (or with a wet/dry vacuum cleaner), then run a cycle without soap of any kind. Hopefully, that will get rid of the mess.
Oct 29, 2009 | Dishwashers
No water at dispensser
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 03, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
