How do i connect it to a molex plug and the sata. The back of the dvd has no pins for molex plug. There is only I type of connector........very slim and not as big as an ide connetor (I assume this is sata connector). Sorry if this sounds daft but I am new to this.
    Guru:
  • 377 Answers
If it is not pin type it will be a sata cable connector there are cable connectors you can change IDE to SATA
Posted on Aug 29, 2010
Replacing DVD/CD drive
Look inside of your tower, you will have a few different cords connecting to your DVD/CD drive.
It should either have a 4 pin Molex connector and an IDE or a Sata connector and power.
The IDE cable looks like this:
http://s7d1.scene7.com/is/image/officedepot/311075_vw_etz00_10055684?$OD%2DLarge$
The Molex connector looks like this:
http://assets.hardwarezone.com/2009/img/data/articles/2004/1215/tutorial-4pin_molex_power_conn.jpg
IDE is an older tech that uses a 4 pin molex to connect it.
Now, if you have something that looks like this:
http://www.sierra-cables.com/Cables/images/SATA-Signal-Cable-1.jpg
It uses Sata, and the power cable looks like it as well, it's just longer.
To make sure the DVD drive you're working will work with the current DVD/CD's you have, just look on the front of the CD you are going to use, in truth it usually should work with anything. It's even RW so you can re-write data to RW CD/DVD types.
Pretty much, just make sure that it uses the same power type and data connector as your current one. Power type being the 4pin molex or the Sata power plug. Data type being the IDE cable or the Sata cable.
If it matches, it will work :) I hope this helps.
Feb 26, 2013 | Dell Inspiron 530 Desktop Computer
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
P3 DVD connector
Well........................
The numbering for power supply cables, differs from one pre-built computer manufacturer, to the next.
GENERALLY, a P3 power cable is a 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Also misnomered as a 'Molex' power cable.
Molex came out with the design for the power cable CONNECTOR.
The name stuck. Kinda' like calling an adjustable open-end wrench, a 'Crescent wrench' )
A P4 power cable is usually a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This power cable was brought out to provide more power for the motherboard, and specifically the Processor. (CPU)
Does NOT connect to an optical drive. (CD/DVD drive)
DOES need to be connected to motherboard though, because it is POWER for the Processor!
Moving on.............
Let's dispense with the antiquated numbering of the power cables, and show you the real information you need;
There are two types of Optical Drives out there, currently being used;
1) IDE. Also known as PATA.
2) SATA
An IDE optical drive will use a 4-pin Peripheral power cable,
Note the rounded corners on top.
When plugging in one of these power cables, just always remember the rounded corners go on TOP.
The data cable used is a flat IDE ribbon cable. These are general examples,
Illustration,
http://en.wikipedia.org/wiki/File:Nappe.svg
Photo,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
I would like you to look at the connector end, and specifically the Locating Lug on one side of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
This style of Locating Lug consists of two small 'bars'.
There are types where it is filled in. Just one solid lug.
The Locating Lug lines up with a Cutout, on the optical drive.
(Or IDE/PATA harddrive)
IF, there is no Locating Lug on your IDE/PATA flat ribbon cable, post back in a Comment.
I will show you the proper way to connect it, using the Red stripe on the side of the cable.
http://en.wikipedia.org/wiki/Parallel_ATA
If you have a SATA optical drive, it uses a SATA power cable.
This is a general example,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Between the SATA data cable connector, and the SATA power cable connector; the SATA power cable connector is the larger of the two.
SATA data cable connector has 7 contact pins.
SATA power cable connector has 15-pin.
This is an example of a SATA data cable, and it's respective connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening. The SATA power cable also has this L-shaped opening.
Observe the SATA data cable connector examples, on the motherboard.
Note the L shape.
(Note: The SATA data cable connectors on YOUR motherboard, may differ in style.
The ones shown (Red) are an Open design.
There are styles that are Enclosed. Have an oval around the
L shape)
To install the cable connector, line the L-shaped opening, with the L shape on the optical drive connector.
Tip: Turn this L over to the left, then turn upside down.
The small 'foot' of the L, always points DOWN, when installing connector.
The SATA data cable connector, that plugs into the optical drive, should be a 90 degree bent elbow.
The connector end that plugs into the motherboard, should be a Straight connector.
The SATA power cable connector, and the SATA data cable connector; MAY have a Lock on top.
Usually a small depression, or Tab, or 'bulb'.
Depress with your thumb tip, to install, or remove the cable.
(Hmmm, betting now the P3 power cable may be a SATA power cable.
How'd I do? Post back in a Comment)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 02, 2013 | E-Machines eMachines Desktop PC
How do you install an hd204ui
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
molex to power sata converters
ide lead which will locate itself by the blank
http://www.amazon.com/gp/customer-media/product-gallery/B0001Y8UI4/ref=cm_ciu_pdp_images_all
molex 4 pin power lead
hope this helps
Jun 23, 2011 | Samsung Computers & Internet
This is my first build and all the connections are a bit confussing need picts of how to install cables to hardware
The following picture will definitely help you to install new power supply.
The 4 pin CPU power connector is using in most of the desktop motherboard. If your motherboard is gaming type or workstation board you need to connect 8pin CPU power connector. Molex connectors are using to power up DVD Drives and HDDs. In New model power supply instead of molex connector SATA Power connectors are coming.
Feb 12, 2011 | Thermaltake Toughpower XT TPX675M 675W ATX...
Hook up fro WD3200 SATA hard drive. I am trying a new power supply and I dont remember how the harddrive was connected ,DoH Do I need both the SATA and the 4 pin molex connectors connected ?
You cannot use a molex connector on a SATA hard drive. You need to connect one of the black plugs from your power supply and the SATA (red) cable from *********** board.
Best wishes,
Graemevm
Mar 09, 2010 | Computers & Internet
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
How do i install dvd rewriter with windows 7. There are different conections at the rear of the factory fit DVD...?
You generally only need 2 connections for an optical drive to work: Data and Power. Data will be either IDE (long 40 pin ribbon cable) or SATA (small [~1/2"] 'L' shaped connection for a much thinner ribbon cable).
Power will be either Molex (4-pin connector with red, black, black, yellow wires) or a SATA power connector that looks like a larger version of the SATA data connector).
All other connections are not needed, such as the small 4 pin audio connection which usually hooks up to the motherboard or sound card, but is only needed for analog playback of audio disks.
Dec 30, 2009 | Computers & Internet
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
