Question about Miele Optima G2470SCVi Built-in Dishwasher
Miele 2470 does not rinse properly. The motor seems to be stuck because it makes a buzzing noise
    Scholar:
  • 91 Answers
Hi dear.According to what you're saying,there is a problem with wash pump.Please do this before take any action, remove the filter & check for any obstacles.if there is any clean it & run the machine for test.If this did not work then there is a little capacitor on the main wash pump.That's causing the problem & needs to be chage.If you can do it,try to replace the capacitor "?uF"same as the original type.It should work perfectly.I hope that helps.Thanks.
Posted on Sep 02, 2010
Why does Miele indicator stick on 'rinses'?
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
Mar 24, 2016 | Miele Washing Machines
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Optima G2470SCVi Built-in Dishwasher Logo
395 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
