Question about Pride New Mobility Celebrity 3 wheel Scooter
I have a 6 year old SC4000 Celebrity (with 6 mo. old batteries). I noticed when I plug-in the charger the ammeter doesn't move. The 5 amp fuse had blown and when I attempt to insert a new fuse I get an arc (charger not plugged in). Has the charger gone bad, needing replacement or is there another area that I need to troubleshoot? Any insight would be appreciated. KK in Anacortes, WA
  • 384 Answers
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
Posted on May 24, 2009
  • 16 Answers
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Posted on Aug 01, 2010
  • 5 Answers
SOURCE: No Power on my Victory when not plugged in.
is the freewheel mechanism engaged if this is not the case I suggest you check all the wireing looms and also check each wire individually it may be that some are broken or have simply not been connected up to each other or may have been connected wrongly to each other and really you should not be useing the lights or the horn when it is plugged in to the charger some types of scooter also have a reset switch usually beneath the rear shroud some where usually you are able to access this by putting your hand into the opening that the seat post goes through upon the rear shroud although if you are not aware of exactly where it is you may find it easier to remove the rear shroud to find it also strip all the plastic shrouds from the scooter front and rear and check all the connections of the wires and make sure they are clean and have not become crusted up with rust or any thing else for that matter and if they have then ueing a mall wire brush or a piece of sandpaper clean them up and re-assemble them make sure you only do one at a time though to make sure you do not connect them up wrongly alternativly if one wire proves to be faulty then it may be easier and better to dissconnect it at both ends and rip out the faulty wire and get yourself to halfords or a similar shop that sells car parts and buy yourelf some wire as well as a crimping set for connecting wires and there individual connectors and then rewire the faulty part or parts try useing a circuit tester on all the vires for each and every individual wire until you have tracked down the fault or the faulty parts or components and replace what ever is faulty or maybe faulty clean up all the connetions make sure that no rain or moisture has got into or affected the parts or the connections as they will and can short out also test and check out the circuit boards and if it is thee that need replaceing it may be cheeper to just brek the scooter down for spares and sell the spares off seperatly and put any money you gain into a piggy bank until you have enough to buy another second hand scooter or even a new scooter although you must make sure any of the parts you do sell are in good working order as if it is te circuit board that are at fault unless your able to replace them or fix them cheaply then it is not worth keping the scooter intact and you are better scrapping these parts as they cost too much to replace unless you are lucky enough to get another scooter of the same make and model type that i working except for say the seat or bodywork or sub-frame is not any good and then from these two scooters make one good one if it is possible as the parts otherwise are not worth the cost of replacing them however check that you have got the correct battery types as they should be sealed lead or sealed gel batteries as some make the silly mistake of buying themelves a couple of car batteries or similar thinking that it is going to be a cheap andeasy fix that will work however this is not the case also do not recharge the battery for a few minute or an hour or two but leave them charging up over night or at least for 8 to 12 hours however if it is not the reset switch or any other problem that can be easily be resolved check about in the free ads and other various places that advertise cheap and free scooters and scooter parts to see if you can pick up the parts you need cheaply good luck and bet wihes I hope your problems are resoved soon and quickly
Posted on Oct 01, 2010
wcdoc1953
  • 278 Answers
SOURCE: Sundance will not take a
On the older sidekick(sundancer) there is an ATO fuse in a rubber boot under the pyramid shaped cover to the rear electronics console that runs to the meter on the pyramid. The newer sundancers have no rear fuse at the electronics tray for the charger. You more likely have a bad charger which is causing an inhibit condition. Usually the scooter will drive away with the charger plugged in until the capacitor drains (1 minute). By unplugging the charger you can get the scooter to run. Check the fuse and the meter connections, then replace the charger with the newer Maximizer style charger with the harness adapter kit.
Posted on Nov 25, 2010
  • 63 Answers
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Posted on Jan 17, 2011
Where is the battery located?
Battery is not taking a charge. Have you checked the condition of the batteries with a hygrometer or voltage meter?
Oct 13, 2015 | Pride Celebrity X 4-Wheel
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Feb 20, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Ammeterdoes the ammeter have plastic clips tohold it in place?
Nobody can likely help you if they do not know what year, make and model you have.
Sep 19, 2014 | Cars & Trucks
How do you hook up amp meter for battery charger
DO NOT CONNECT IT to both poles + - !!! the amp meter have very small internal Ressistance, it blows of :) Connect it like in the picture d640b1d6-15c8-40ff-9dc1-eac0eb3b2a1f.png
Apr 16, 2014 | Cars & Trucks
The ammeter on my jet 3 does not move at all when chair is plugged in.
If your ammeter does not move when the chair is plugged in...
You may have a burnt fuse ,check your fuse link connected to your ammeter..
You may have a bad charger, volt test your on board charger..
Good luck I hope i was helpful
Jan 16, 2011 | Jet 3 Ultra Power Chair
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
When I plug the battery in for charging, the charge light does not come on. only the power light on the charger
There are several solutions to this problem which I have seen twice in my technical career.
You indicated that the power light on the charger comes on which indicates it is plugged into a working AC wall outlet. Check to make sure the power switch of the charger is turned on. Make sure that the round charger plug is plugged all the way into the battery charger receptacle on the battery box.
Next, check the on-board fuse AND the circuit breaker. I have had this little 5 Amp automotive style fuse burn out on several go go's and the charger does not work. Pull back the cover over the charger port and look for the fuse in its center slot. With a good set of fingernails it can be pulled straight out and inspected. Use fine needle nose pliers if necessary. I am assuming the go go runs and the push-button for the 15 Amp circuit breaker is pushed in. If it is out and the go go is not running reset the breaker by pushing the white button in. There is a clear rubber boot over the button. In my experience, the 5 amp auto fuse is your most likely problem. By holding it up to the light you can see if the fuse wire inside is burnt causing an open circuit. Most auto and hardware stores have this fuse in stock. Bring the old one to the store for comparison. It is a 5 Amp ATO fuse.
The question my clients often ask is what caused the charger circuit to overheat and the fuse to blow? The simple answer is that the two 12 Amp hour batteries in the go go are probably old and weak. This causes the charger to work too hard and the circuit to overheat and the fuse to blow. These small batteries have a short life span of between 6 months and 1 year depending on type. I recommend the AGM (advanced glass mat) batteries for longevity. Also make sure the charger being used on the chair is the 2 Amp small charger that came with the chair (There is a label on the charger to verify this). A larger charger will burn the batteries(shortening their life) and burn out the 5 Amp on-board fuse. Hope this helps.
Oct 31, 2010 | Pride Mobility Products Go Go Ultra X 3...
The ammeter says its fully charged, but when driving the scooter the gauge goes into the red...is it the gauge, the ammeter, the batteries, or the charger?
I suspect this will be the batteries. The fact that the ammeter is working suggests the charger is charging the batteries. Just to be certain, the ammeter should start at a higher figure (i.e. 4 - 5 amps) the more discharged the batteries are, and should read zero when the batteries are fully charged. If this is the case, I think the charger and the ammeter are ok. The battery guage should also be ok as these do not usually move at all if they are broken. Batteries can take a, and even hold a charge for a certain period of time if they are weak, but under load, they cannot produce the desired amount of power. It sounds to me like this is your problem, but before you buy new batteries, have them checked properly as other things may be to blame, like a brake problem or even a motor or transaxle problem.
Sep 13, 2010 | Electric Mobility Mobility Electric Power...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Dead and wont move cant charge but batties are ok
May 24, 2009 | Pride Celebrity Xl 4 Wheel Scooter
Pride New Mobility Celebrity 3 wheel Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
