Question about Amana Heating & Cooling
Model CCA36FCC Mfg No P1258004C Issue: The fan on my AC is running, but it does not appear to be cooling. Thermostat = 73 Indoor Temp = 81 Outdoor Temp = 94 Fan set to AUTO; System set to COOL Verified that breaker is on, and fan is running on outdoor unit, nothing obstructing on outdoor unit, no airways indoors are obstructed. My service technician was just here for an annual system check a few weeks ago, so not sure what is wrong. Black control box near the system is blinking a red light...cannot find any documentation on what to check. On the black box are the words: Smartway Solution Inc MSV-10. Do you know what I need to do to get the system to start cooling again?
  • 32 Answers
Find another teck sounds like its low on freon if it has a txv it could be malfuncitioning!!!
Posted on Aug 30, 2010
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
Why is My 04 PT Criuser running hot and there is coolant in the radiator ?
check your cooling fans make sure they are working, to do this start your engine and turn on the ac the cooling fans should be running, if it does the next thing to check is the temp sensors, to do this turn off the ac, while the engine is running keep an eye on your temp gauge if the dial is going up above normal or at the point where you say the engine is running hot check if the cooling fans are running,
1) if not running, cooling fan sensor is not working, replace
2)if running, thermostat is shut, the thermostat regulates the flow of coolant in the engine it is fully open at normal operating temp and close if coolant is cold, replace
how to replace thermostat go to https://www.youtube.com/watch?v=dG5MhY8Bieo
Aug 16, 2014 | Cars & Trucks
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
2001 chevy malibu Ls - Cooling fans on constantly, fuses are good and the temp. gauge at zero. Inside fan is blowing heat so the thermostat is open. Relay? Are the cooling fans hooked in a series to...
turn ac off then the fan will go off make sure ac button if you have one isnt pushed inwait a minute fan should turn off does temp gauge inside car raise in temp after running a while
Dec 08, 2010 | 2001 Chevrolet Malibu
2002 Jetta 1.8T blew 40A cooling fan fuse - overheated, destroyed 4 way cooling hose connector - replaced all- now it still runs very hot, inside temp reads 190 (but temp is much higher), cooling fans run...
Then replace the thermostat, because if on lower hose not hot and on upper hose scalding hot = antifreeze flow blocked by the thermostat wich remains closed!!!
Thermostat replacing:
Aug 27, 2010 | 2002 Volkswagen Jetta TDI
No power to ac indoor fan motor
sounds like you might have a bad control board. try putting a jumper wire on the control board low voltage terminals R and G your fan should come on and run if you have 120v power to fan motor. double check that you do have 120 leaving board and going to motor. if no 120 bad board if you do have 120 bad motor. if it is the board it likely has a bad blower relay which is common in amana models and goodman equipment.
Sep 13, 2009 | Amana Heating & Cooling
Power outage/AC not cooling
ok if you have split system if indoor fan runs then transformer is working you have 2 breakers 1 for indoor and 1 for out door also disconnect at unit may have fuse in it if all seem ok remove side cover and look at capacitor if sweeled up bad take an insulated object and push in contactor if runs check for 24v from common to yellow stat wires also look for reset button next to freon lines hope this helps
Jun 14, 2009 | Whirlwind FH-778 Air Conditioner
Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Apr 19, 2008 | Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
