Question about Vacuums
Bought a sewing machine called vogue stitch and need to know how it works from a to z
  • Vacuums Master
  • 11,800 Answers
 Vogue Stitch has been an older local (US) brand for Husqvarna machines - their production ended at least 15 years ago. During that time they produced more than 100 different models. If you need a manual for one then please post the model number. By the way the manual for one of these has over 150 pages so no way you can see it here. Your best chance of finding one for an older model is some enthusiast forums like
http://www.sewusa.com/  or  http://forums.allcrafts.net/forumdisplay.php?f=29
Posted on Aug 29, 2010
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
Singer Stylist 7258 will only sew backwards and is only making holes...no stitches!
this link is for the manual go to page 32 ,it sounds like you have it on button hole stitch witch goes in revers, you need to press button hole off switch.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Oct 23, 2012 | Singer Stylist 7258 Electric Sewing...
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I bought it from a yard sale, with no instruction book, and i cant get it to sew a strait stich, it sews zig zag only even if i change knob control, I cleaned it oil it, help?
Hello:
You don't say what model this sewing machine is, or how old. Some older machines had cams that created different stitches. (they sort of look like weird little cogs)
Did it sew ok before you clean/oiled it?
Mar 12, 2011 | Vacuums
I bought a Tacsew T8700 High Speed Stright Stitch and I should have paid more attention to the 'High Speed'! The motor that came with this industrial machine is a Tacsew Clutch Motor model: RM1878-1H. It...
If you are just starting off sewing and don't have good foot control change the motor to a d/c motor they are about $120 and you can turn the speed of the motor up or down
Mar 01, 2011 | Vacuums
Looking for a signature sewing machine model # UHT J276A
I have one, I bought it for the cabinet for another machine. There is no manual but it does sew, I tested it. It looks like it has been very used. I could not test the fancy stitches without a manual.
Oct 27, 2010 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Vacuums
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
