Question about Bakers Pride BAK-DS805 Gas Single Oven
Timer?for y 600 deck oven
Is there a on off timer for the gas on a bakers pride y 600 oven .Its becoming so expensive to leave oven on overnite at low temp.
  • seapanda Jun 10, 2008
    same problem..how to turn oven on using a timer..propane fired..no help from bakers pride
    Novelist:
  • 125 Answers
Hi there. If you have an older oven, it most likely does not have a combination valve with a thermopile, not the same as a thermocouple, or a hydraulic safety. If there is a red button sticking out the panel where your thermostat is, you have a hydraulic safety. What you want can be done with wiring, solenoids,timers, and the correct location in the gas line, but would require a bit of modification. I would only use a servicer for this type of modification, if they will even do it, could you find someone to do it, with little concern about safety? sure, but it must be understood, you are taking the risk, and responsibility. This is definitely not a do it yourselfer task.If you do have a combination valve, it would have a door over it, and the valve would have a knob that you turn for " off/pilot/on" in this case, if you put a timer in series ( inline ) with the thermostat wiring like a light switch, open or closed, with the timer function, this would make it stop heating from whatever time you set it to start/come on, till the time you set it to stop/ turn off. Just be aware now, that your unit will be operating unattended at times, and if it was to have a problem, someone makes a mistake, etc.. now no one would be there to help, or shut it down. So be sure this is acceptable risk for you.
Hope that helped, and thank you.
Posted on Mar 08, 2009
I got the same problem....................no solution so far
Posted on Jul 04, 2008
Http://www.fixya.com/support/t24431241-bakers_pride_commercial_oven_flames_turn
I would suggest that the thermostatic gas control valve is faulty and you will require a Gas Safe engineer to verify and replace the item.
Jul 26, 2014 | Bakers Pride Y-600 Gas Single Oven
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
I have a Bakers pride y-600 oven . What is the best way for top door to be taken off ??
On the left side, remove the knobs and cover. The spring holding the door closed needs to be removed. Have someone hold the door closed while removing the door spring. Now let the door open and you will see two screws holding the door to the door rod assembly on the left side. These screws are usually 9/16. After removing the two screws, the door will pull off the door pin that is located on the right side.
Oct 24, 2013 | Bakers Pride Y-600 Gas Oven
Stones get too hot, burns on bottom before top cooks
Assuming you have the oven adjusted properly maybe the thermostat might need to be replaced?
I would try and adjust the flame to a lower height before replacing the stat.
Oct 23, 2010 | Bakers Pride Y-600 Gas Single Oven
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
Bakers pride electric deck ovens aprox 10 yrs old
It depends on the ampere rating, you will not normally be able to get a single phase supply in the UK at more than 100 amps total.
If the total oven rating is not more than 60 amps you may be ok.
Conversion would involve altering the wiring in the oven which may be costly and not worthwhile on a 10 year old oven.
Jan 06, 2010 | Bakers Pride CO11-G2 Gas Double Oven
Ran out of lp gas -now furnace and water heater will not light
yes you will have air in it you will neede to pruge the line near to the heater
Sep 18, 2009 | Bakers Pride Y-600 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
WAISTING GAS BAKERS PRIDE GAS OVEN DOESNT SHUT OFF
Hi, don't know if you received an answer, however your gas valve sounds to be bad, when turned to pilot, it should only allow gas to the pilot assy. The problem is, it has already failed to shut fully, if it still does that with it in the off position, it would still be allowing gas through it, if the pilot goes out, there is now no protection to shut itself off, get it replaced ASAP. Hope that helps, and thank you.
Sep 28, 2008 | Bakers Pride C011-E2-C Gas Double Oven
Thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
May 19, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers Pride BAK-DS805 Gas Single Oven Logo
140 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
Paul Carew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
