Question about DeLonghi BAR 32 Espresso Machine
Describe your DeLonghi BAR 32 Espresso
Machine is dripping out hot water badly in heating stage and after coffe making the dripping does not stop
  • 3 more comments
  • IS45 May 15, 2008
    I the outlet valve ( little cooper bolt with spring and teflon (?) plug ) unde r upper filter is worned out. I did not find the exact part number for this and I dont know wer you can by a new one. The Professional service in our area said no part for it....?
  • IS45 May 15, 2008
    where can I buy a spare or replacing parts for it parts for it?
  • IS45 May 15, 2008
    how can I check out the thermostat?
  • IS45 May 15, 2008
    machine is dripping out hot water badly in heating stage and after coffe making the dripping does not stop
    I think the outlet valve (thermostat?) ( little cooper bolt with spring and teflon (?) plug ) under upper filter is worned out. I did not find the exact part number for this and I dont know were I can buy a new one. The Professional service in our area said no part for it....?
  • Anonymous Mar 18, 2014
    When fully turned to off hot water drips from the nozzle when coffee is being made.
    President:
  • 2,712 Answers
Try 888-411-5282 (JAVA) or 585-924-7170 or FAX 585-924-7362
Whole Latte Love - 596 Fishers Station Drive, Victor, NY 14564
for the part required..
Posted on May 15, 2008
    Brigadier General:
  • 3,614 Answers
Try to use an alternative way, try using rubber gasket.. to fix the worn teflon
    Sergeant:
    Champion:
  • 230 Answers
Many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
  • 796 Answers
Check whether the sealing is done properly...
there may be some discontinuity..
    Guru:
  • 1,894 Answers
I think your thermostat is dead
have u check it out?
  • dewan nafees ahmed May 15, 2008
    is company person says that there is no part avilabe means i think u cant do anything with that.
    but u can very well try with local service centers
    they may help u with some alternative
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
How do I make an espresso one shot. Machine only makes regular coffee which pores water
Good morning
When when I want to make an espresso in my DeLonghi I adjust the water and the coffee. Mine is manually operated so it was trial and error to come to a good cup.. Enjoy your coffeekolbrun
Jan 11, 2015 | DeLonghi Coffee Makers & Espresso Machines
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Delonghi coffe maker leaks water from bottom
The problem is that the heated water is leaking out of the drip chamber. This is caused by the fact that they were to cheap to use stainless steel screws that hold the chamber top to the bottom. The screws have rusted and the hot water can escape the drip area and runs down next to a plastic tube that delivers the hot water to the top of the coffee maker from the heating element. To repair you have to remove two screws that are on the underside of the hot water drip area above the coffee filter. Then there are 3 tabs that have to be released and separate the cover that has the strength control from its base. When you pop off this cover, you will see the remains of 4 screws that are badly rusted. I used a small ez-out and drill to remove the remains. Be very careful to not drill the pilot hole through the top. I got lucky and was able to remove the screws and replaced them with stainless steel. An alternate method would be to use a food grade 100% silicon adhesive and glue the to back together. This method may leak in the future, so try to get the old screws out first.
I would recommend a MR coffee $30 to $50 models, on sale, for coffee before I would ever buy this European designed junk. I took this thing apart and just shook my head and said that you can tell things that aren
Jan 26, 2009 | DeLonghi Caffe Nabucco BCO70...
DeLonghi BAR 32 Espresso Machine Logo
1,076 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
