Question about Kenmore Washing Machines
My Kenmore Elite top loading washer keeps filling with water even though I switch it to the next cycle. It spins and drains fine during spin cycle, but keeps on filling with water. Also, the spinner/agitator starts as soon as the lid is closed for the wash cycle even though the water has not filled up. Once the water does fill up to the correct level, it stops filling, but then restarts when the water drains out even though it may be a spin cycle.
    Champion:
  • 274 Answers
Its suppose to start with lid down,the draining may be a faulty water level switch so this needs replaced.
Posted on Aug 29, 2010
  • psingh488 Aug 29, 2010
    I dont think its supposed to start agitating even if the water has not filled up (dry clothes). Also, the wter stops filling when it reaches the required level, so the water level switch mmay be working fine. But it starts refilling when the water is drained, and fills even during the spin cycle when its not supposed to take in water.
2 Suggested Answers
  • 249 Answers
SOURCE: kenmore top load washer starts agitating as soon
sounds like a timer problem
Posted on Jan 01, 2010
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Elite HE3t- suds-
advance machine to drain/spin cyce to remove the water.if it doenst drain and just "humms". try removing the lower access panel. just behind it youll find the pump assy unscrew the face and empty the contents (probably lint, baby bock, assorted stuff from pockets)be prpared though the hose above is FILLED with water. Make sure your using HE detergent!!!!!!!!!!
Mar 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Brand new kenmore HE2 front load washer - keeps filling
Either your pressure switch is bad, or the air line that connects to the presuure switch has come loose. The pressure switch is located on the right-hand side rear of the washer with the top cover removed. It is a brown colored, disk shaped, device with an electrical connection and an air hose connection. Sometimes this hose comes loose in shipping, or the electrical connection may be loose. Without it, the washer will continue to fill and will NOT shut off. Now...if you just purchased this unit, DO NOT do anything that will void the manufacturer's warranty. It may be an inconvenience, but I would recommend you get the appliance repairman to come in and take a look at it. That way...you won't be held liable if something were to break. This is, however, usually a simple problem and not considered major. I hope this reassures you some. Post back with comments if you have any further questions/concerns.
Nov 11, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
712 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
