The air conditioning does not turn on when I adjust the temperature on the thermostat. I can't find the manual and I don't know how to reset it.
    President:
  • 3,074 Answers
Http://www.manualnguide.com/dl/9665/
Posted on Aug 29, 2010
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
Tip
Becoming more efficient with your heating and cooling
Here are some ways to become more efficient with your heating and cooling. Obviously you do not have to do them in order but try to complete as many as you can! = )
· Buy a laser thermometer! You can use this to detect air leaks (or at least areas with “minor” temperature differences) so you know where to put seals
· Keep blinds shut on hot days and open on cold days----helps reduce temperature extremities
· If the temperature is can be negated by using a t-shirt or a jacket, use that clothing! You will save temperature control costs and still be able to keep warm or cool
· Do not use those old lightbulbs on hot days---they make extra heat increasing cooling bills (but you can use them on cold days to help warm your house)
· Utilize energy star products to increase efficiency comfortably
· Set your thermostat as low as is comfortable in the winter and as high as is comfortable in the summer.
· If you are on vacation, turn of that air conditioning/heating! No one will be in the house if everyone is away and it shouldn’t be too uncomfortable to wait like one hour for the house to cool/heat
· Don’t turn your thermostat up/down just to heat/cool faster---all temperature control changes the house temp at the same rate and if you forget to turn it off, you just wasted some energy there!
· Don’t block heating/cooling vents so that your rooms can be controlled quickly and so that your air actually gets controlled, not your furniture
· Check up your air conditioning and heating systems regularly (not once a month but maybe once every year) so that the systems stay running the best they can
source:
http://www.savingsnut.com/heatingcooling.html
on Dec 07, 2009 | Heating & Cooling
My air conditioning will not turn on. The thermostat control has only four buttons,two adjusting the temp up or down,one turns the fan on or on auto and the other selects the system cool heat or off. When...
After setting the unit to cool and adjusting the temperature, the compressor should run if the light stops flashing. Check the condenser, if the fan and compressor does not run, check the contactor if it is energized or pulled in. If the contactor is not pulled in there must be no power or the holding coil is open. If the condenser fan is running without the compressor, check your compressor, high pressure switch, and capacitor.
Sep 09, 2011 | Honeywell Heating & Cooling
2004 XG350 - when the outside temperature is in the 40's to low 50's, I set the temperature at 78 degrees and never raise or lower it. The car warms up quickly, but after about 15 - 20 minutes (in my 45...
I also own a 2004 XG 350 and I agree with you. The first thought that comes to mind is a malfunction in the Auto AC control module (that's the virtical console unit which you adjust the fan speed, Auto, Mode, Recirculate, etc. are located). The other thought which occurs to me is that you might have a 'low engine coolant' condition (but that would eventually turn on your "Check Engine Light" and a code would be set indicating the Thermostat was not working properly). Did the Svc Mgr scan your vehicle for any DTC's (Diagnostic Trouble Codes)? If he didn't (or if he didn't have a technician do it), then you'll want to have that done so you'll at least know this may not be the problem. Sometimes the thermostat can stick 'OPEN" and the engine doesn't reach it's operating temperature (which is where you get the heat to warm up the inside of the car)... so, if the engine is 'COLD' so would also be the coolant and it's the coolant that brings the heat into the passenger compartment (via the heater core).
Feb 10, 2011 | Hyundai XG350 Cars & Trucks
Adjusting thermostat temperature
nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
May 27, 2009 | Heating & Cooling
Honeywell programmable thermostat
It sounds like you might have the same problem that we have. I read the manual and it says that thermostat has a special lock to prevent tampering. It could be locked. If you override it only last a while and goes back to its original settings. The manual says you need to contact the person who installed it. In our case the person who was in charge when when we had it installed is no longer with the company. We don't know who installed it.
Jul 29, 2008 | Honeywell Programmable Thermostat Heater
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Thermostat set to low.
If your A/C has a digital control panel no screw driver is necessary to reset the temperature.
http://www.frigidaire.com/products/
resultspage.asp?strmodel=FAA065P7
The above URL will take you to the site to download the owners manual for your model number stated.
May 11, 2008 | Frigidaire Compact Air Conditioner
My air conditioner doesn't turn on, what do I look for?
If your room air conditioner doesn't go on at all: 1) Check the power source first: be sure it's plugged in and turned on. 2) Then check the outlet by unplugging the air conditioner and plugging in a light that works (only for standard-voltage models--do not plug a light into a 220/240-volt receptacle!). 3) If the light doesn't go on, the circuit has probably overloaded--check the electric panel or fuse box and reset the breaker or replace the fuse. 4) If the light works, it's likely that the air conditioner's switch is faulty or the thermostat needs adjustment or repair. 5) Be sure the thermostat is set to "cool" and below room temperature. 6) Refer to the manufacturer's instructions for thermostat repair. If adjusting or repairing the thermostat doesn't solve the problem, unplug the unit and call an air conditioning technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
