SOURCE: e4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
SOURCE: water damage
Ones has to take the phone apart, remove the battery and all parts that are removeable.
please read this wikihow
http://www.wikihow.com/Save-a-Wet-Cell-Phone
If you need anything else let me know.
Thank you,
Ekse
SOURCE: manual for uniden TRU9480 4
Hi streck - Below is the link for your manual. The manual is the same for all 9480 series phones no matter how many extra handsets you have. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.uniden.com/pdf/TRU9480om.pdf
Jeff
SOURCE: I have a uniden cordless phone model tru9480-3
With the phone in standby, press and hold [dnd] on the base. You will hear a confirmation tone and the [dnd] LED will go out.
Testimonial: "Thanks IT Worked"
SOURCE: I have a Uniden TRU9480 5.8GHz Phone and the
I found this elsewhere:
I've fixed this by taking the phone apart, finding where the pressure pads are under the button. I glued a small piece of aluminum foil on to where the pressure pad is. Aluminum foil is a good electrical conductor. It's a delicate process. I don't recommend doing this unless you know what you're doing. But if your handset is already dead/useless, give it a try. Put everything back together and the buttons work again.
