Question about Mk Diamond Mk 115V Electric Water Pump
I have a Diamond laundry pump model # 399094. After a short period of initial usage, the pump keeps running even though the water is all pumped away.
115hp 4 stroke mercury no water stream (***) though no overheat alarm came one afer motor ran for about 10 minutes. Normal? Believe it is a 2008 model and has not been used for 2 years
when outboard motors are not used for a period of time, the rubber blades of the water pump break of in the first application on start up. It is possible that a piece of blade has blocked up the tell tale hole and there is some blades left to pump watre through the motor. I suggest that you replace the water pump before serious usage as they do fail if not used.
Oct 22, 2014 | Boating
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
Adjusting my Pentax hydromatic H1 water pump
we need wiring diagram for achromatic 1. the power supply is 240 v 50 hz
Nov 26, 2012 | Cars & Trucks
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Have a little giant 4-mdqx-sc that I bought used I plugged it up dry just to make sure it runs and it is making a horrible noise from the impellier not the motor will this go away when it is in line with...
yes it should go away, this is a magnetic drive pump so it needs water to lubricate the porcelain shaft, it's not good on it to run it dry for long period of time just a short time, these pump eventually wear and will need to be replaced. they seem to last 2-5 years .. and back pressure is not good, so if say running a fountain bleed off excess water do not use a valve to restrict flow.. this is how we get the 5 years instead of the 2 ! .. jay the pump guy longwood fl
Jan 24, 2012 | Little Giant Garden
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Not draining water away
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 07, 2009 | Zanussi Washing Machines
Won't drain, cycle keeps on going
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 20, 2009 | Washing Machines
Mk Diamond Mk 115V Electric Water Pump Logo
134 people viewed this question
Top Mk Diamond Plumbing Experts
Donni Steen
Tom Chichester
Are you a Mk Diamond Plumbing Expert? Answer questions, earn points and help others
