My air conditioner was barely blowing air out of the vents when i looked down stairs the filter was dirty but only a month old. i also noticed condensation on the pipe with black foam/rubber insulation on it. also a sopt where the rubber was ripped had frost i turned my a/c off but have no ideal what the problem is please help
  • 43,501 Answers
You have a leak in your A/C unit and the system is low on freon...
Get a pro to look at it fix the leak and recharge it...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 29, 2010
My unit does not go on. I press the on button and hear it then 10 sec pass hear it but it doesn't light and red light doesn't go on and then it shuts off
tep 1: Check the thermostat
  • Make sure that your thermostat is set to "cool" and not "heat" (if it's set to heat, your AC won't turn on no matter what).
  • urn the temperature setting 5 degrees below the current temperature to see if your AC will turn on.
  • No good? Then you need to...
tep 2: Check the air filter
  1. Find your return vent's filter (the return vent is where air gets sucked into the air conditioner).
  2. Check to see if the filter is dirty (if you can barely see light coming through it, it's too dirty).
  3. Change the filter if it's dirty.
    "Wait, why am I doing this?"
    A dirty air filter blocks air from returning to the AC, reducing airflow over the evaporator coil, causing it to ice up.
    This causes a low-pressure switch to trip and shut down your AC's compressor (the heart of your air conditioner) to prevent it from being damaged.
    So you need to change the air filter to prevent all that.
Sep 28, 2016 | Heating & Cooling
Barely blowing out of vents even with filter out. Not cooling the house down . The copper line from outside to inside has frost on it
Your indoor motor is going bad and not running full speed...
heatman101
Sep 04, 2010 | Goodman CLQ36AR49 Air Conditioner
I own a Zenith Air Conditioner, model ZW651OR. It is only a month old and it is not blowing cool air any more. I live in Guam (relatively a hot climate) the size of my room is 10' X 12' and the air...
The problem could be dirty filters, dirty coil, refrigerant charge low,etc. Since it is only a month old I would try to return it if possible.
Aug 25, 2010 | Heating & Cooling
My a/c is blowing cold air, just not as hard as it used to. Don't know what to do. Don't what to waste money on a repair man if it something I,am just overlooking.
Besides your motor going out, somethings to check would be dirty/clogged air filters, dirty indoor coil, or dirty fan blades on the blower motor itself. The only other problem that would cause this would be a broken section of duct if you don't have slab ducts (concrete floor). Hope this helps!
Aug 17, 2010 | Ruud UAKA037 Air Conditioner
AC on but nothing coming through vents
the therostats adjust a damper to open air flow . it could be a damper motor problem. or it could be the ajustment of the tstats. turn the up stairs up then go to down stairs turn it down. then see if the air is flowing. i hop this helps
Apr 15, 2010 | Ruud UAKA037 Air Conditioner
18 year old Janitrol Heat Pump freezing up.
i would get someone to check your refrigerant levels have you ever had the evaporator coil flushed and cleaned? proper refrigerant levels and proper airflow across coils are extremley important not to scare you but 18 yrs is a long time on a heat pump 9-12 years is the point where they really loose there efficiency going for a newer one would probably cut your operating cost in half if not more depending where you live there are a lot of people not familiar with heat pumps so i suggest finding a company that specializes in them to service your unit
Jul 30, 2009 | Ruud UBHC Air Conditioner
Central air conditioning system
Check the filter(s). Dirty filters is the primary cause for such failures. Secondly check the thermostat and make sure that it is not turned way too low. Anything above 70 is safe from causing freezing on the unit. If the unit is already frozen then turn the unit off until it is totally thawed and then retry.
Jun 30, 2008 | Heating & Cooling
Appliance
The only possible explainations for your situation is that the air is either going around the filter and going straight to the coil or the air filter is on the wrong end of the furnace. The air should go through the filter before it goes through the furnace. If you can take the filter out and look at the coil, the air should be sucking into the furnace from that end, if it is blowing in your face, that is the problem. If all is ok with that then take a close look for where the air could be getting in without having to go through the air filter. Seal up any holes with duct tape or sheet metal or both.
Jun 28, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
