Question about NEC MultiSync LCD1735NXM (Silver, Grey) Monitor
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
    Sergeant:
  • 223 Answers
Sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Posted on Aug 29, 2010
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    Did that do the trick? or were you able to find the speaker configuration in the control panel
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
Jan 30, 2014 | Audio Players & Recorders
Magicjack problems
Magic Jack stores your messages as an AUDIO FIle. You play them back via Microsoft's player program. If your audio program is not working, then you can not play them back. Check and see if you can play a music file from the sample music folder. It works OK, then Windows Audio is fine. If not you may have turned off the Audio. Look to the lower right side of the computer screen and you will see a small speaker. Left click and see if the VOLUME is set to an audible pitch suitable to you. Check the master control and make certain it is on, set to the type of speakers you use. If all the settings are correct and the sound level is OK, then you should be able to play back your messages. Write back if you still have the same problem.
Jan 01, 2014 | Computers & Internet
Audio problem streaming media via ROKU and RCA players. Constantly have to adjust volume to hear them talk, but then the music/sound effects blast you out.
It sounds like you're using a set of stereo speakers to play a surround sound output. I would try going in the TV menu and turning off surround sound
Dec 23, 2013 | Televison & Video
Whats the correct setup for home recording on the samson L2400 mixing console
To avoid feeback whilst recording, make sure all speakers and monitors are turned off while you record. Otherwise the microphone will pick up both the sound of your voice from your mouth as well as the sound of your voice coming out of the speakers, causing an endless loop of nasty feedback! So just make sure speakers (incl. computer speakers if those are what you are using to listen) are muted whilst recording!
Apr 30, 2012 | Audio Players & Recorders
Gateway dx4840-11e. During video can hear music but not actor voices. What to do?
do you have the sound set to surrond sound? What it sounds like is that it is trying to play through surrond speakers but you dont have them, which is why you can hear the music and not the actors voices. click with the right mouse button on the speaker in the bottom right of your screen, then click on sounds , now click on the playback tab in the sound window, click on the sound device shown and then click configure, choose stereo and choose two speakers. Continue to the end then try to play the video and see if you can now hear the voices. If you cant then you maybe missing codecs needed to play the audio correctly. Please state if this is a movie you have downloaded or a dvd film on disc etc
Apr 02, 2011 | Gateway Desktop / Intel Core i3 Processor...
When i play a game such as Battlefield Bad Company 2 on the Xbox 360. The sound works, like you can hear the water flowing, aircraft etc etc, all that is is fine. But when it comes to audio of different ...
Most of the sounds you are hearing good are background sounds. If you are running a surround system, you might want to try adjusting the output of your primary speakers, checking for the correct setting on your receiver, and verifying that your central audio is in the correct section ( receiver output ).
If you are not using surround sound,
Check the in-game menu (Pause) for an audio section, some games allow you to turn the character voices up and the music down. If you don't have that option, try using a new output cord from your xbox to Tv.
Mar 10, 2010 | Logitech Z-5500 Computer Speakers
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Speaker not working?
no always the the voice speaker is located to the front of the phone but the song/ringer speaker is located to the back of the phone so you will have to take the phone to a mobile service center and have them replaced the speaker.
Feb 13, 2008 | Sony Ericsson W800i Cellular Phone
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
NEC MultiSync LCD1735NXM (Silver, Grey) Monitor Logo
283 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
