Question about Magellan Maestro 3225 Car GPS Receiver
Won't turn on at all, even connected to either charging source
  • 22,306 Answers
Make sure the charger is working,use a test meter and if it has power then leave it plugged in for 24 hrs to overcome the internal resistance of the battery ,if that doesnt work then as they can be bought for 97euros in our local big electrical retailers just bin it and buy a new one ,you could try taking it apart and looking at the switch and by passing it if its not working but in all honesty these things are made in china for a price and its just not worth the effort
Posted on Aug 29, 2010
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
What can this issue be? Pls I charged the battery for over two hours and it still won't start even if I have jumpers attached?
Gary, Do you mean car will not start, or do you mean it will not turn over. If it does not turn over, even with boost, battery cables bad,starter relay or fuse bad, or starter defective.
Trouble shooting links below.
Show your appreciation and press the helpful button and follow me on fixya for more tips and info
Engine Won Crank or Start
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiN1MOfp_3KAhWltoMKHdZPA4YQFgghMAE&url=http%3A%2F%2Fwww.agcoauto.com%2Fcontent%2Fnews%2Fp2_articleid%2F253&usg=AFQjCNEZxvRFnI5ZWt5HxxASWILn8ksLSA
Engine Won Start No Crank Diagnosis Troubleshooting Starting System Issues
Feb 16, 2016 | Cars & Trucks
I barely got this camera. It wouldn't turn on so I
What make and model camera?
Not all USB ports put out enough current to charge a battery. If you're connecting through a hub, try bypassing it and connecting directly. If you have another USB port, try that.
Apr 26, 2013 | Cameras
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
M802 tablet won't charge
Had the same problem and it turned out to be a bad charger. If a charger is needed go on the internet type in what kind and it take you to a source to get it. The cheapest place is Ebay I paid under $20.00
Apr 23, 2012 | Computers & Internet
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
I have an MP3 player by Dell and it won't charge. I don't have the original power cable so I use a USB cable.
Some personal players charged via usb connection take a certain charge and some are even set to not recognize or to prompt you when you use an alternative source that does not fit the specific charge. You should buy the proper cable or an aftermarket one that specifies compatibility with your specific player. This is only a troubleshooting method as the player may have something wrong with it and may need to be fixed. Please repost when you try a compatible cable and the community can help you further.
Jun 03, 2011 | Audio Players & Recorders
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
Magellan Maestro 3225 Car GPS Receiver Logo
24 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
