Question about Whirlpool Dishwashers
It doesn't seem to clean the dishes very well it comes out with some kind of white coat like limescale or something
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
Can I use citric acid to clean out the limescale from my coffee pot? It looks horrible and is starting to affect the taste of my coffee.
Limescale needs something stronger than basic dish soap to remove it. Citric acid and vinegar are both very good products for cleaning coffee pots. Using a ratio of about one part citric acid to 20 parts water, brew the pot of coffee as you normally would. After that, do another 2 cycles of 'brewing' using just plain water. This should clean your coffee pot out nicely. Good luck.
Feb 25, 2013 | Home
White coating on dishes and cutlery
This is caused by hard water, suggest you have a water softwater installed.
Dec 27, 2011 | Miele DA 5100 D Stainless Steel Kitchen...
Dishwasher runs, but the water doesn't seem to get hot and the dry cycle doesn't seem to be working. I ran a cycle with a bottle of dishwasher cleaner. It has little wax stopper that blocks the...
No there is not a reset button on diswashers. I would suggest you take the heating element out and check it with an ohmmeter to see if that is the problem - which is the most probable cause. If it is open - infinity reading on the ohmmeter, then it is bad.
If it is good then, it would be the control board.
Aug 14, 2011 | Dishwashers
How to clean lime scale out of iron tank
All you need for this is a cotton cloth and white vinegar, a small amount. And you have to rub with cotton cloth for the limescale. Vinegar will act and the limescale will disappear from here.
If it doesn't help you can mix the vinegar with baking soda and it will be a good start point.
When you have finished to polish and to clean the outside, you can clean your iron from inside. For this you have to put a small amount of vinegar and you have to mix it with water.
You have to switch it on to wait. And press the steam. All the limescale will come out of there.
You see? And your iron is shiny and clean, from inside and from outside as well. .
May 19, 2011 | Tefal Irons
The dishes do not seem to come out rinsed, especially the glasses. There seem to be small particles of food left on them and overall everything seems coated with a layer of gunk. I've made sure that the...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 10, 2010 | Bosch Dishwashers
Dishes and particularly glasses coming out cloudy
Yes. pour two cups of white vinegar into the empty machine. Run your hottest and longest cycle. Always turn on the hot water in the sink and let it run as hot as it will get before you start your machine.
This will clean your machine. Repeat this cleaning as often as necessary. J.
Jul 17, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Coating of white on dishes that doesn;t come off
usually caused by a combination of too much soap, too hard a water source and no rince agent. Run some vinegar in a cycle without any dishes ( or soap or anything else). a bit stinky but won't stay . then you could do it again with the dishes to clean them up.
Aug 20, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
My dishwasher leaves a "White Residue" on the inside of the drum and all over my dishes. What can I do to stop this from happening?
the machine needs a thorough cleaning with limescale remover and dishwasher cleaner
Kind regards and please don't forget to rate us
Dec 09, 2008 | Dishwashers
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
DWU8260aax dishwasher, Maytag
What kind of soap do you use??? How much??
Nov 23, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
