Question about Kenmore 31079 Upright Vacuum
Hi we have a model 31075 which i did not find in the list im hoping it's similar to the 31079 The problem is that the agitator has stopped working and i can not open it to find the problem is there a manual available or a site i can go to. Can you suggest what i can do to open it to look around I am very handy with most things but this thing has got me frustrated at this point. thanks for your help. Regards Chuck
    Master:
  • 347 Answers
Well, that was a lot of fun. I'm pretty certain that your number has been preceeded. Follow the link and I think you're good http://www.searspartsdirect.com/partsdirect/user-manuals/11631675100-Kenmore-Parts-Vacuum-Parts-manual
Posted on Jul 22, 2017
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
I need a new roller brush for Kenmore model 31075 vacuum. Is it interchangable with other models
no is NOT interchangable, you must buy from Kenmore.
God bless you
Jun 18, 2012 | Vacuums
Hi i recently brought a beautful riccar sewing machine in fab working order older style 1960s with no manual having trouble threading and can not find model numnber anywhere. any advive?
Here is a link to a site with threading diagrams for some Riccar models. www.sewusa.com Hope they have your model, if not look at the ones they have should be very similar. Hope this will fixya up...
Apr 25, 2011 | Riccar Vacuums
I have no owners manual and need to replace the belt on a Hoover powermax model #:U5242-930 can you help thanks Bab
I don't see this unit on the Hoover support site. However other Powermax vacuums come up in the search for manuals: http://www.hoover.com/CustomerService/manuals/Default.aspx .
Most of the units have very similar belt replacement procedures. First unplug the vacuum. Then press the handle release lever and place the handle in the low position. Next remove the hood by turning the two slots either side of the hood with a coin. Rotate the hood towards the front of the unit and remove it. Then remove the agitator brush roll and the old belt. Discard the old belt.
With the lettering to the outside, slide the new belt over the motor pulley. (The old belt should have been on the pulley. If the belt broke and isn't in place, look for it on the right as you look at the front of the vacuum above the agitator brush roller's position.) Slide the agitator brush roller through the belt and place the belt in the belt guide on the roller. Grasp the agitator and put it into position. Fit it into the rectangular slot on the left. Then pull it into position on the right side of the vacuum. Check if the agitator and the belt turn freely and that the belt isn't pinched between the agitator and the bottom of the unit. Replace the hood by aligning the tabs with the slots on the base. Then turn the coin slots to secure the hood.
I hope this helps.
Feb 01, 2011 | Hoover Powermax U5242-930 Vacuum
The brush has stopped turning when used in the upright position
I have one too and I'm trying to fix it as I write this.I also have an older version and I've had no luck.I've taken evey screw out ,spayed tweeked and tried everything possible.my solution would be to stay away from Hoover steam spin scrubs.I'm going to invest in one with brushes like a vacuum.Those that are easily replaced as well as the drive for it be it a belt or a turbine like I've read this unit has
Apr 20, 2010 | Kenmore 31913 Progressive Direct Drive...
MY VACCUM WILL NOT PICK UP THE DIRT SO HOW CAN I FIX IT
There are two things that can cause an upright vacuum to stop working
A: Air Flow or Suction-Make sure that the air flow is not impeded by a clog, full bag, or dirty filter.
B: Agitation- Make sure that you have a good belt, the roller is engaged, and that the height adjustment is set appropriately. Most vacuums need a belt change about every six months whether it is broken or not.
You may want to ask a more specific question with your make and model number included.
Hope I could help
Good Luck
Nov 21, 2008 | Vacuums
My Model is a U5465-900 - I need to replace the agitator housing.
I don't seem to be able to find a site with entire replacement parts list. Or a cross reference to the U5465-900 model. It has a 15" agitator. The housing has been "rubbed" through at one side of the agitator and is no longer capable of containing the agitator in the proper position.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can check your local vacuum dealer in you city or state and they sometimes will have a micro fiche or breakdown of your particular vacuum or you can contact the Hoover Factory Website listed below --- or check your owner’s manual for a parts breakdown or check the yellow pages in the city or state you live in
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 15, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Kenmore 31079 Upright Vacuum Logo
91 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
