Question about Peg Perego John Deere Gator HPX Ride on Toy
Hi Sir. I replaced the switch and made sure the battery was charged. The lift gate operates well. The toy will not operate. any suggestions? How to diagnose the problem?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 13, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: no power to back wheels
Sometimes I have used meters on these toys and received false readings due to numerous tabs in the switches.
As long as the wires are secure, I would replace the high/low switch and the reverse switch.
You can get the parts here http://www.shopjandl.com/
I get all my Peg perego parts from them and they seem to know what they are talking about if you need any help.
Posted on Jun 01, 2009
Need to replace the liftgate switch, where can I get instructions to do that?
How do you know it need's a switch ?
Rear Hatch/Gate Description and Operation
The lift gate can be opened by operating the switch on the instrument panel. Battery voltage is supplied to the lift gate actuator through the body control module (BCM). The BCM will pulse the lift gate actuator when a release input is received through the key fob, or the instrument panel switch. Did you test voltages ? Check for BCM DTC'S - diagnostic trouble codes ?
Circuit/System Description
The lift gate switch is an input to the body control module (BCM). The BCM supplies battery voltage to the signal circuit and when the lift gate switch is activated the signal circuit voltage goes low. The BCM controls the lift gate release actuator assembly through the LIFTGATE relay. When the lift gate switch signal is activated, the BCM enables the LIFTGATE relay by applying battery voltage to the lift gate relay circuit and the relay is energized when the BCM grounds the LIFTGATE relay control circuit. When the relay is energized battery voltage is supplied to the lift gate release actuator assembly through the lift gate release actuator control circuit.
May 29, 2016 | 2008 Pontiac Torrent
I replace the mothrboard on elite slidding gate but the batery loses power
Since you have a battery and it is a sliding gate, I will assume you have a Roboslide model by Elite. The battery has to be charged in order for the gate to work. The charging comes from a transformer or a solar panel. Check to make sure these have power coming out of them. Most gate operators use a transformer and if the two wires providing the voltage touch each other, it will blow the transformer. If you have a volt ohm meter you can check this. You might need to use the AC setting as well as the DC since some are 18 volt DC and others are 25 volt DC. You can do the same for a solar panel but only use the DC setting.
If this is not your issue, then make sure it is your battery draining and not something binding in either the motor or the gate. Finally, it could be the motor going out. Simply hook the charged up battery directly to the motor to check it. It should respond strongly. Reverse the leads to make the motor go the other way.
Good luck.
Mar 08, 2015 | Elite Sl 3000 Ul Sliding Gate Operator
My 2008 equinox tail gate will not open,checked fuse, replaced battery in remote, disconnectedbattery and re-connected, flipped the interior switch in lift gate to open but still not working
check the circuit board to the signal receiver. if that fried then you gotta replace it because its not sending the signal. Or check the circuit line make sure its getting power to the gate. Going have to open a lot of stuff to get to them wires.
Sep 28, 2014 | 2008 Chevrolet Equinox
GMC Acadia Power Lift Gate Not Working
Will require a scan tool to check for codes, make sure latch is working well, make sure release switch is getting signal. Most common concern is the latch itself though
Jan 19, 2014 | 2008 GMC Acadia
Had battery replaced at Auto Zone, now the "lift gate ajar" light stays on and the lift gate will not operate electrically. Any ideas? 2006 Mercury Monterey
make sure batt is reading 12.6volts-any points less effects a computer car--testit with a voltameter--if ok then disconnect it and restart car to reprogram again
Sep 14, 2013 | 2002 Mercury Mountaineer
Lift gate suction stopped working, any ideas?
It can be faulty switch or its issue with lift gate latch. Its got stuck up hard or cracked inside. It has to be inspected. -----------
Also if its vacuum operated that blockage in vacuum lines or vacuum motor issue.
There are few help links with proper solutions for this problem. I suggest you to
Click the link below:----
LIFT GATE / TAIL GATE ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/liftgate-will-not-open.html
Thanks.
Dec 14, 2012 | 2009 Infiniti FX50
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
Nov 25, 2012 | 2007 Lincoln MKX AWD
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Dual gate Hurst shifter adjustment
Hello! Here is what I was able to track down:
Hurst Dual Gate Shifter Assembly Parts Breakdown:
Removing & Replacing The Hurst Dual/Gate
1. Disconnect car battery.
2. Remove Knob. Remove four Phillips head screws that hold escutcheon plate down to console.
NOTE: SHORT SCREW IS USED IN REAR RIGHT - HAND HOLE. Remove escutcheon plate and console from floor tunnel.
3. Lift selector indicator lamp housing out of shifter and pull bulb socket out of lamp housing. Disconnect wire connectors from combination Back - up light / Neutral safety switch.
4. Remove two 1/4 - 20 x 1/2 hex-head cap screws that fasten Dual / Gate shifter to rear mounting bracket. Remove 1/4 - 20 x 1/2 hex - head cap screw that holds cable bracket to shifter frame. Remove two #10 - 32 x 3/8 slotted head cap screws that fasten Dual / Gate shifter to front bracket. Free shifter from cable by removing cotter pin and washer.
5. Remove combination Neutral - safety / and Back - up light switch. Install switch on Replacement unit.
6. Install replacement shifter unit in reverse order of removal of original unit.
7. ADJUST CABLE: SEE FIGURE 1 (Below)
Loosen nut that fastens cable pin to transmission control arm. Loosen nut enough to allow pin to slide in the slot in the arm. Turn the arm to NEUTRAL position. Move the stick to NEUTRAL. Tighten the adjusting nut. Test movement of stick and check to be sure that stick positions agree with transmission control operation.
8. SEE FIGURE 2 (Below)
Connect car battery. Apply hand brake. Move stick to NEUTR AL position. Press foot on brake pedal. Start engine. If starter fails to operate, Neutral Safety switch must be adjusted. Adjustment is made with a long-bladed Phillips screwdriver through the "Street" gate. This screw is directly in front of the st ick. Turn the screw about 1/2 turn past the point where starter operates. (STICK MUST REMAIN IN "NEUTRAL" WHILE ADJUSTMENT IS MADE). Starter should operate ONLY when stick is in PARK or NEUTRAL position.
Hope this helps and thanks for using FixYa!
Oct 22, 2009 | Pontiac GTO Cars & Trucks
I am charging the mercedes ride-on car, but it will not run
A few simple checks before operating this type of toy can ensure safe and proper operation.
1.) make sure that the toy is switched to the 'on" position
2.) make sure that the battery cables are connected properly. Ensure that you have the correct polarity as these toys usually run on DC (direct current) power. The red wire plugs into the red wire and black wire plugs into the the black.
3.) Make sure that your battery is fully charged. The owners manual specifies charge time. Too littleo r too long of a charge may ruin the battery and cause a malfunction.
Good luck....hope this helps.
Feb 23, 2009 | Mercedes-Benz Toys Toys 622226 Mercedes SL...
Peg Perego John Deere Gator HPX Ride on Toy Logo
47 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
