Question about Frigidaire Affinity ATF7000E Front Load Washer
Code E 70 on a 6000
Any idea
  • Anonymous Aug 22, 2008
    e 70 means the hot and cold water connections are reversed
  • 770 Answers
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
Posted on May 10, 2008
What is Restore factory resetting password of micromax q7 mobile as i am unable to make any call and phone message appears as "Not allowed".
try below reset code
Micromax Q7 codes
*#8375# - Software Version
*#8929# - Reset
*#1111# - WiFi
*#87# - Auto Hardware Test
*#1234# - A2DP Normal/PTS mode (no idea what PTS Mode is)
*#900# - BT Local Test (no idea about use)
*#901# - BT Local Test 1 (no idea about use)
about 3 weeks ago
Jan 24, 2011 | Cell Phones
IDEA net setter Huawei CE0682 FCC ID : QISK2540 IMEI: 353474029263274 S/N: D84CAA1952006672 just I chenge my GPRS Network than it want unlock code so Pls. give me idea net setter unlock code
dear sir
I hv idea netsetter [HUAWEI CE0682]
MODEL=E1550
IMEI 352965040583922
i am using idea netsetter but now i want to use another sim in it but i changed airtel sim asked a password to unlock code pls tell me this device code
i can use another sim in this device
just i chaing my GPRS network than it want unlock code so pls, give me idea netsetter unlock code urgent sirrrrrrrrrr
Dec 31, 2010 | Computers & Internet
My idea sim is asking puk code
hi...
this is caused because you might have entered a wrong pin code more than 3 times. please call you service provider(idea) and ask them the puk code. they wil give you.
thanx
Jul 15, 2010 | Nokia 1600 Cellular Phone
I WAS MESSING WITH MY MOBILE.SUDDENLY I ENTERED THE ''PIN CODE REQUEST'' IN MY L.G. MOBILE MODEL NO.GM200 IN WHICH IDEA SIM WAS INSERTED. THE NO. OF THAT IDEA MOBILE WCHICH I WAS USING WAS ''09525279255''....
If you need the PUK ( Personal Unblocking Key ) for your phone, you will have to contact your mobile phone service provider.
PUK code is related to the SIM card you are using. So, kindly call the IDEA Customer care number from another IDEA mobile and they will provide you with the PUK code.
Also, entering a wrong PUK code ten times in a row disables the SIM card permanently. So, please be careful while entering the PUK code.
Hope this solves your problem. Thanks for using FixYa.
May 24, 2010 | LG GM200 Cell Phone
Puk and pin code urgent
call idea customer care by any other idea user and ask for your puk code by telling them the numbers on the other side of your sim card and your sim contact number............
they will tell you your puk code...........
Feb 22, 2010 | Nokia 2626 Mobile Phone
My idea sim is blocked. it is asking for puk code. plz help.. my sim card no. is 89917811060443421618- Guest
hi, puk code is coming with network provider.. So you can call to Idea customer care and give your simcard number and they will provide you..Puk code...Hope this will help you....Thank you....
Nov 05, 2009 | Nokia 1100
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
I have idea netsetter huawei EG162G MODEM its work with idea sim only can some unlock its to use other operator its imei no is 353474027400605 and sreril no is D82AA12921300854 PLZ REPLY THANKS
EG162G usb modem.my IMEI no is: 353474027386069 & s.no.: D82AA10921300899. i have idea net setter HUAWEI. but i want to use other network. but when i put ohter sim card so ask 10 digite unlock code. please help me and give me code for unlock it.
Jun 11, 2009 | Computers & Internet
Security code problem
Hi Enter this Master Code your issue should resolve...where it asks
for Enter Security Code : 4745705746
Regards,
Raju
Jan 21, 2009 | Nokia 1600 Cellular Phone
Idea sim blocked
if u entered wrong 10 times your sim will rejected
u can call customer care and get ur puk code
Mar 14, 2008 | Nokia 1100
Frigidaire Affinity ATF7000E Front Load Washer Logo
1,103 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
