Question about Whirlpool GEW9200L Electric Dryer
No start light are on but nothing happens .When i push the stert button it clicks and does nothing.I have checked the thermo coupler nad for fault codes which i get an "E3" any ideas?
    President:
  • Whirlpool Master
  • 2,651 Answers
E3 fault??? sounds like an open sensor, located right nest to the thermaal fuse.
Posted on May 08, 2008
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
Heating wont come on. honeywell system the request box in kitchen requesting for it to come on but thermostat not coming on and boiler in garage not kicking into action hve tried resetting both thermo
Check transformer near on on boiler circuit board. the transformer provides a low voltage power source to operate some thermostats and relays at the furnance control board. May need new transformer also check wiring to thermostat
Sep 25, 2017 | Honeywell Programmable Thermostat Heater
Gg40t6a polit light will only light when polit button is held down.i have cleaned the thermo coupler and orfice at no avail.
Does the gas flame fully heat up the coupler
if not then clean out the gas jet nozzle
if yes then replace the thermo couple
Feb 11, 2010 | General Electric GE SmartWater Household...
The pilot won't stay lit!! Before when this happened, we turned the gas down. It seemed it would blow itself out. Tonight...it doesn't want to light at all.
i should have seen that, sorry.
TDoes it go out when you turn the main control to on? If so, The thermo coupler appears to be not working. The thermo coupler is that bulb that is at the tip of the pilot flame. and has a small tube going to the main valve. It controls all the gas and shuts everything off if the pilot flame goes out, including the gas to the pilo. That is why you have to push the button to light the pilot. Ot bypasses giving the pilot some fuel. to lite. As mebtioned, if the thermocoupler goes bad nothing will work so I think changing it will solve your problem. If the coupler is not in the flame, try adjusting so it is and see if that helps Good Luck -Ned-
Sep 19, 2009 | Water Heaters
Burner will not light, but pilot is on
Sounds like you need a new thermo coupler. this is first and foremost.
Can you light the burners by hand? and do they burn hot and clean that will let you know if you have clear intake lines for the gas.
There is a small chance the gas valve is having a problem,not at the burner control but the vavle the thermo coupler is connected to. or worse case scenario moisture in the gas line.
Feb 02, 2009 | Imperial IFS40 Deep Fryer
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Dec 02, 2008 | Dishwashers
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Whirlpool GEW9200L Electric Dryer Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
