Question about LG GH22LP20 DVD±RW Burner
MY new GH22LP20 will not burn images from my PC using either Nero9 or the software which was bundled with the unit.this may be relevant ,DMA-driver error, CRC error, from the Nero fail log. I can if needed forward the full log
  • A_David_M Aug 29, 2010
    This is a new unit purchased yesterday
    As no cable was supplied with the unit I used the existing cable. I have a CD player too which is slave the DVD is Master as was the one I replaced. The burn process does begin but fails.
    I use the latest edition of Nero and the software issued with the unit was updated.
    I could send the full fail report if you think it may help
  • LG Master
  • 4,924 Answers
First try to uninstall the drive from the device manager ..and than reboot..it should ask to reinstall it on reboot..and take it automatically ..if not ..go to Bios settings ..and in there access the optimal factory defaults..confirm the change ..and than look at the drive settings and the ide must be on auto..
if all that are ok ..save with f10 and out ..
if the problems still persist ..my choice is to select it as master from the pin settings and change the ide cable......and plug it with a 40-pin, 80-conductor IDE cable which is the new stile of ide cables...
Posted on Aug 30, 2010
  • Catalin Turcu
    Catalin Turcu Aug 30, 2010
    by the way ..I should use ISO burn instead..or NERO 7 ...cause the Image files are better recepted by NERO 7 ..unless you have windows7 and it is not supported ..
  • 1,472 Answers
A_David_M
If you are having trouble burning with both programs this could be an issue with the drive its self.
How long have you had the drive for. I normally have to replace my burner about every 3 to 4 years.
Do you have access to another drive that you can try in your computer or another computer that you can try your drive in to see if you get the same problem.
Issken
http://www.fixya.com/users/issken
Posted on Aug 29, 2010
  • Will Hartford
    Will Hartford Aug 29, 2010
    A_David_M
    So what I can tell you have a PATA drive (uses an IDE cable). So you may have a problem with the cable. Did you use the cable that was already in your computer or did you use the one that came with your drive? Is the drive connected to the cable on its own and if it is not what is the drive? What drive is master?
    Also did you use the software that came with the drive or did you have burning software on your computer already?
    If you already have the software you may need to install the software that came with your drive for it to work with the drive properly. Also for Nero you may just need to install the lastest update from Nero to get proper support from the drive.
    Issken
    I used the existing cable as none was supplied with the unit.. I have a CD player also. The DVD is the master as was the one I replaced. I have the Latest edition of nero and the software issued with the unit was updated. The unit does begin to burn but stops. Would you like me me to send the full fail report
380381-26-2A030C00 I get this error code whenever I try to burn a cd. Trying to figure out what is the problem because the burner works perfectly on dvds. Thanks for your help
Trying other burning software is a good Idea, windows itself has native cd burning support,through media player for example. It won't be a codec issue unless you are converting from an MP3 or similar.
Try burn with deep burning
Download it from following bellow link
http://www.deepburner.com/?r=products&pr=deepburner
I personally don't like codec packs, they fill your system with codecs you never use and aren't as up to date as the individual codecs.
I always install Koepis's latest Xvid Codec and AC3 filter and that's it unless something fails to play, then I find the relevant codec.
The question regarding DMA is also worth following up, from device manager you need to check the properties of the IDE controller the drive is connected to - can take a bit of trial and error to find the right one. It should be set to "DMA if available" and the current transfer mode should be something like "DMA mode 2" ( depending on the drive ) If it is in PIO mode that will cause issues.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 10, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
LG GH22LP20 has audio skipping on DVDs and CDs
Do you have skipping on every DVD/CD you burn? If so, then you're probably experiencing what's called 'buffer underrun'. When that happens, the burner writes faster than the computer can send it information, resulting in skipping. In the program you use, look for the 'burn options' and change the speed from 'automatic' to a manual, slower setting. That should fix your problem.
Feb 24, 2010 | LG GH22LP20 DVD±RW Burner
How do i remove the adminstator password off my dell latitude d380 laptop
For Dell password reset, you can use Windows Password Rescuer to help reset password easily. It can help reset Windows 8/7/Vista/XP/2008/2003/2000 administrator password quickly without logon.
You also can use Password Recovery Bundle 2012 to reset it.This Tool can recover password for Windows, Word, Excel, RAR etc.
Nov 29, 2009 | Dell Latitude D830 Notebook
Not recognising cds and ejects them
If you have SP3 installed, try removing it. It makes problem with some optical drives.
Try new Free Nero 9
http://www.nero.com/eng/downloads-nero9-free.php
Sep 05, 2009 | Dell Computers & Internet
I have just purchaced alg gh22lp20 dvd drive but
the computer should recognize it as a dvd-device though, if not windows is giving u trouble,
so try using any other
freeware burn program like nero or burnatonce to burn,
u necessarily need the original software.
to get anew copy of software email the manufacturer, then post send the cd in exchange for a newer one or look on th homepage if they have something fittng your drive- model and operation system ready to download...
good luck
Sep 01, 2009 | LG GH22LP20 DVD±RW Burner
How do you burn a dvd?
you can easily burn a dvd by using a software called Nero (http://www.nero.com/ena/nero9-introduction.html).
the software quite popular since CD writer were manufactured.
email me at cjoenic@gmail.com if u need the software and also dont forget to rate me up..
May 03, 2009 | Ahead Software Nero 9 Full Version for PC
Placing print on Nero9 images
You need to use the Nero Image Editor that comes with Nero and look obviously for the Text option or the slanted capital T. If not you can edit your image in a program like GIMP (free, just do a search on Google) and then re-import into Nero9.
Jan 23, 2009 | Computers & Internet
About nero
Nero is software for burning CD and DVD...
u can download from here
http://ftp22.nero.com/Nero9/Nero-9.0.9.4c_trial.exe
Dec 12, 2008 | Ahead Software Computers & Internet
LG DVD Writer
re-install after un-install the burning application.
Nov 04, 2008 | Computers & Internet
LG GH22LP20  DVD±RW Burner Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
