Question about Indesit W 123 Front Load Washer
Indesit WIXXL146 washing machine will not turn on
I've done all the bog standard basic checks, nothing wrong with the fuse, plug or the socket that he machine is plugged into. I have cleared the filter out just in case. When I switch the power on at the socket the washing machine is plugged into, all fur green lights and the red neon on-off/door locked lights all immediately flash up to indicate power to the machine. However, when I turn the on-off button to start the wash load there is nothing - no red neon nor any green lights come on. Any ideas as to what I can do to try an fix this? I do have plumbing skills I just am not a washing machine expert by any means. However I am not afraid to get stuck in so any knowledgeable suggestions you can offer will be greatly appreciated. Many thanks for your help in advance, JD.
  • 66 Answers
Sounds like interlock or pcb try lock first as this is cheap to replace regards jason
Posted on Jun 15, 2008
Have a WIXXL 146 that ist heating water, no fault codes are showing in the lamps, machine otherwise fine. Is the easiest way a resistance check on the element?
Try a volt meter first, if you are getting voltage the next best thing is a clamp amp meter. Resistance will be probably less then 15 ohms (guesing). I have added a link for the manual.
Indesit WIXXL 146 Instruction Booklet
http://www.manuals365.com/swf/indesit/wixxl146-gb-hires.html?page=12
Mar 02, 2015 | Washing Machines
Indesit washing machine does not turn on
If it's tripping breaker, there is a wire shorted somewhere.
Nov 07, 2017 | Washing Machines
No power to my Indesit Washing Machine.
PCB has suffered a catastrophic failure due to the power cut, it will need to be replaced. if you have a power cut in the future always turn off your appliances, as the voltage can exceed the appliance recommended voltage. only leave a light on as lights can take the over voltage unless they are led type, you can but power drop sockets that when power is off it turns of the socket off so no power goes thought to the appliance.
Feb 01, 2018 | Indesit W 123 Front Load Washer
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
No lights on indesit washing machine
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 04, 2011 | Indesit W 123 Front Load Washer
Hi i have been away for few days washing machine was fine i dont use it very often as i live alone and takes a while to acumilate enough washing to use the machine. its a WIL163 Just loaded the washer...
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 20, 2011 | Indesit Washing Machines
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
Jun 10, 2009 | Washing Machines
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
988 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
